Philips 55OLED907 vs LG G5
Redders
I have a 2.5 year old 2023 Philips 55OLED907 and I’m considering swapping to an LG G5. Can anyone advise, would there be an appreciable and noticeable improvement in picture quality? I know both were/are classed as flagship, has the tech moved on significantly in 2.5 years? TIA
Hi Red you have a very good TV already and with B&W sound .I have the LGC3 the picture is excellent but the TV speakers are not so good .
If i was you i would go and demo a few LGs and see if its worth the spend .
I would imagine putting them side by side you may notice some very minor differences. The G5 has the layered panel for example and a slightly wider colour gamut. The Philips has some good processing and is no slouch at all though. I would suggest it likely sounds better than the LG as well. But away from having them set up next to each other I doubt you could tell much difference. The year on year upgrades bring minor incremental improvements. In your position I would keep the Philips for a few more years yet. I know the itch to upgrade is always there, but I doubt you would see much benefit at all. Will make it all the more worthwhile when you do upgrade.
I have LG C4 65' and the picture quality is excellent. Most of the time, I have the sound playing through the TV speakers, rather than my AV setup, the sound is pretty loud and adequate for my needs.
The Phillips I would hold on for a while longer, not unless you're looking to upgrade to a much larger screen, which would make sense going from 55' to a much larger screen.
Ps.
The up-scaling on the LG from 1080p to UHD / 4K is very good, no washed out colours or artefacts from the upscaling. I think this is one of the technologies that continues to improve.
Reactions: Holt
