Panasonic TX32LZD85 - red pixel on the screen
Hello, I think I need advise. On the screen in my brand new LZD85 (yesterdays purchase) there is a red/pink coloured pixell displayed. It is almost invisible on coloured picture, however where white colour is displayed it is annoying. Even if it is very small it is visible from distance 2m due to contrast between the white background. I have connected that TV to PC via HDMI instead of standard VGA port but I do not think it is making any difference. I have changed resolution couple of times but it does not help. It is still the same red/pink point. Maybe swomeone could help me and tell me is it a fault of the screen, something wrong with that particular pixel? Do you think should I replace it for different unit? Thanks
If you can still see it when watching the built-in Freeview, then it will be a dead/stuck pixel. If you have the option to swap it, you should do it immediately.
