Hiya
I have a Pro-Ject debut 3 turntable that has the factory fitted Ortofon OM5E cartridge with the letters "OMB" on the side of the cartridge. A few years ago I upgraded the factory fitted Ortofon 5 stylus to an Ortofon OM10 stylus. Now I need to replace my worn stylus, and I'm wondering if it's worth upgrading the cartridge at the same time.
My choices are to keep the factory fitted OM5E cartridge and replace the OM10 stylus with the same stylus model, or to replace the factory fitted cartridge with an Ortofon OM10 cartridge and replace the OM10 stylus with the same stylus model.
In other words - I'm going to replace my worn stylus with the same model, is it worth upgrading the cartridge at the same time?
Can anyone recommend either of these two choices, or suggest any other practical possibilities?
Chris
Chris
