Steady hand and patience 👍 When you've made your choice please let us know your thoughts.I have set up 1 or 2 cartridges in my time I do have a cartridge alignment tool and a few test records but ive not changed one for quite some time though.
I'd be leaning that way as well....I note that on the Ortofon site its says that silver has a life of around a thousand hours if looked after so recon mine is defo toast i will have a look at the Blue but if im being honest im leaning toward the AT's
The Sumiko cartridges are only installed on US Project turntables simply because they are manufactured in the States not because they are better than the Ortofons. Standard cartridges on European decks are Ortofon.Thanks for that tip I will have a look at those cartridges would you rate these above Ortofon cartridges?
I have no clue, I haven't owned a turntable since 1991!Thanks for that tip I will have a look at those cartridges would you rate these above Ortofon cartridges?
I wasn't suggesting that they were better. It's just a potential option as they are used as OEM and I don't think Pro-Ject is going to put junk on a $1,000 TT. Perhaps they are not easily available in the UK... I wouldn't know.The Sumiko cartridges are only installed on US Project turntables simply because they are manufactured in the States not because they are better than the Ortofons. Standard cartridges on European decks are Ortofon.
Gotcha... thanks, even though you lost me in the second line.Sumiko / Project share the same importer in the USA
Project design & factory fit ortofon for the rest of the world 2+ million cartridges
Sumiko are brand labelled by OEM Excel in japan , 100s of suppliers of cartridges by all make by 5 OEMs
PS All Sumiko cartridges are manufactured in Japan, as the name would suggest.The Sumiko cartridges are only installed on US Project turntables simply because they are manufactured in the States not because they are better than the Ortofons. Standard cartridges on European decks are Ortofon.
To my surprise, the McIntosh Group owns Sonus faber. The McIntosh Group are ultimately owned by a Dallas based equity firm called Highlander Partners.To my surprise, Sumiko are now listed on Henley’s website fitted to some newer Pro-ject turntables priced in £.
Henley Audio | T2 Turntables |
Pro-Ject take their first step into the world of vinyl wi-fi playback.www.henleyaudio.co.uk
Right its still a work in progress if I can get over to richer sounds in Cheltenham tomorrow they have the Ortofon Blue all the AT's ive been looking at and the Sumiko cartridges in stock so Im up for blowing around £150 ish on a new stylus /cartridgeAnyway, I'm more interested to know what the OP has decided on doing with his sibilance problem. New cartridge or just replace the Ortofon stylus?
Are you going to take the tt with you so that they can 'expertly' fit whatever you decide to buy?Right its still a work in progress if I can get over to richer sounds in Cheltenham tomorrow they have the Ortofon Blue all the AT's ive been looking at and the Sumiko cartridges in stock so Im up for blowing around £150 ish on a new stylus /cartridge
It's your money, but I think your stylus is due for replacement after 4 1/2 years/900 hours!The other thing I thought of doing was plugging in an old Rega Mira amp I have to see if I could hear the same issue with that . One of the speaker connections get a bit crackly when its warm but it does work mostly.
Probably not ive ordered a few other things to help me set it up like an Azimuth Ruler Cartridge scales etc im an Auto engineer by trade so I should be able to sort it I have set up cartridges a few times but if I get into trouble ill take it Richer sounds or Audio T and get then to sort it.Are you going to take the tt with you so that they can 'expertly' fit whatever you decide to buy?
Do they even offer such a service?
Oh its still getting replaced as soon as I can get one but the amp thing was just to see if I could hear the issue with another amp. Im still of the opinion that its a mix of a knackered stylus and my new Amp pulling a lot more detail out of a record as im playing other records im finding stuff/detail that ive not heard before good stuff tho ;-)It's your money, but I think your stylus is due for replacement after 4 1/2 years/900 hours!
That I did know! Sumiko were the authors of a well known speaker setup guide for Sonus fabers. Fine Sounds very kindly sent me some elastic strings for the grilles on my Sonus fabers even though they were imported before their business came into being. No charge either!To my surprise, the McIntosh Group owns Sonus faber. The McIntosh Group are ultimately owned by a Dallas based equity firm called Highlander Partners.
Global business networks are indeed a complex web of connections!
Sumiko (a McIntosh company) distributes the 'Fine Sounds' portfolio into the USA and 'Fine Sounds UK' imports McIntosh, Sonus faber, and Bassocontinuo for the U.K. market.
Sumiko itself is American with headquarters in Minnesota...., Don't let the name fool you.PS All Sumiko cartridges are manufactured in Japan, as the name would suggest.
Both the Moonstone and the Rainier seem to be well reviewed by the Hi Fi press, including WHF.
Listed as MN because that's where their parent group (Fine Sounds... part of the McIntosh group) is headquartered.Sumiko itself is American with headquarters in Minnesota...., Don't let the name fool you.
Not sure where their cartridges are actually made though
Excel Sound is a hi fi store in Orange County that imports Hana. They have nothing to do with Sumiko. There are scores of small artisan cartridge manufacturers in Japan. Small workshops with just one or two dozen skilled technicians assembling bespoke designs by hand.Sumiko appear to made in Japan by Excel Sound. Excel also make Hana carts. If you dig deep enough there is a surprising amount of root origin commonality hidden behind different brand names.
Good job you didn’t buy a 2M Black stylus! A Blue is decent enough and surely better than your worn out Silver, but I sense a change is incoming. Good luck, and let us know what you decide.I am feeling a bit better that i dont have a £600 cartridge on my deck.
