Ortofon Recommended load impedance > 20 Ohm
Internal impedance, DC resistance 5 Ohm
Output voltage at 1000 Hz, 5cm/sec. 0.3 mV
20-60Ohm input to a SUT step up transformer & feed directly into iyour phono stage 47k moving magnet input
example, 0.5mV, when used with a step-up transformer with a 1:10 turns ratio, would produce 5mV at the transformer's output. Yes, it would if the cartridge's source impedance (also known as its internal impedance or its coil impedance) was zero. In practice, with low impedance cartridges of about 10 ohms or less and low ratio transformers (less than about 1:20), the transformer's output voltage is very close to the cartridge's output voltage multiplied by the turns ratio and can be safely used as a good first order approximation for guidance. However, the cartridge's source impedance may be low but it is never zero, and the transformed secondary load needs to be considered for a more accurate analysis. Consider as an example a transformer with a 1:10 ratio and a cartridge with a 10 ohm coil. If the load on the transformer secondary is an MM phonostage with a 47k impedance, that load appears to the cartridge as 470 ohms (47,000 divided by 10 squared) and must be driven by the 10 ohm coil.
