Which listening mode to use on the Onkyos for the PS3 input via HDMI. Direct or Multi-channel?
A admin_exported New member Aug 10, 2019 2,556 4 0 Nov 16, 2007 #1 Which listening mode to use on the Onkyos for the PS3 input via HDMI. Direct or Multi-channel?
A Anonymous Guest Nov 16, 2007 #3 I was told to use 'direct' to make the most of the dolby HD audio because it was decoded within the PS3 and then output via HDMI to the Onkyo.
F FoxJA New member Aug 28, 2007 42 0 0 Nov 16, 2007 #4 I have my Onkyo 875 on Direct when playing Blu-Rays through my PS3. I thought you should only use Multichannel if using the multichannel inputs.
A Anonymous Guest Nov 17, 2007 #5 I initially was advised to use direct but multi-channel sounds so much better. As I understand it the PS3 decodes the sound and sends it as multi-channel PCM via the HDMI to the receiver, so using the multi-channel listening mode makes sense.
