Am I right in thinking if my amp can output say 25 wpc at 8 ohms and I changed my speakers for new ones rated at 6 ohms the new speakers will be easier for the amp to drive and the output power could be more ?
BigH said:Yes I would look at speaker sensitivity, ie db over 87 would be better than 84-85. For your amp. I would get some over 87db if you can but I would hear them rather than just go ratings. 90db will be 2x as loud as 87db and 4x louder than 84db, make sure they are measured at same Ohms, but don't take these as gospel they are more of a guide than being dead accurate, same with amps. Best to hear them with your amp if you can.
Laurens_B said:BigH said:Yes I would look at speaker sensitivity, ie db over 87 would be better than 84-85. For your amp. I would get some over 87db if you can but I would hear them rather than just go ratings. 90db will be 2x as loud as 87db and 4x louder than 84db, make sure they are measured at same Ohms, but don't take these as gospel they are more of a guide than being dead accurate, same with amps. Best to hear them with your amp if you can.
To reach 90dB you need twice as much power as compared to reach 87dB, it does not sound twice as loud. So a 90dB speaker will require half the power of a 87dB speaker to get the same SPL. A difference of approximately 10dB sounds twice as loud.
davedotco said:Laurens_B said:BigH said:Yes I would look at speaker sensitivity, ie db over 87 would be better than 84-85. For your amp. I would get some over 87db if you can but I would hear them rather than just go ratings. 90db will be 2x as loud as 87db and 4x louder than 84db, make sure they are measured at same Ohms, but don't take these as gospel they are more of a guide than being dead accurate, same with amps. Best to hear them with your amp if you can.
Be careful with the way you interchange 'loudness' and 'SPL'. Sound Pressure Level is a measured difference in air pressure and is a repeatable, measurable quantity. A 10dB increase is twice the measured SPL.
Loudness is a subjective appreciation of SPL and is entirely personal to the listener. Generally, most people would rated an increase of SPL of about 8dB to be subjectively twice as loud, but it does vary considerably, person to person.
But otherwise, you are correct.
Thompsonuxb said:It'll drive them fine. ... You're worrying over nothing.
davedotco said:Thompsonuxb said:It'll drive them fine. ... You're worrying over nothing.
Maybe, maybe not.
There are, and have been, a fair number of posters who seem to think that some magic combination of amplifier power, speaker power handling and impedance can somehow absove them of the requirement to understand and use their system in a sensible manner. 'Bullet proof' systems really do not exist, it is possible to blow up, in one way or another, pretty much any system by behaving like an idiot, on the other hand virtually all systems are perfectly safe when used sensibly.
In this case, it is simple. The amplifier is not suited to loads below 8 ohm. Will it drive 6 ohm speakers?
If the owner is sensible, does not require high levels, keeps an eye on the amplifiers temperature then it will most probably be fine, work it hard at high levels, don't be surprised if it shuts down (or worse).
