steve_1979 said:I've also discovered that the arms resonant frequency is 9Hz (which is apparently at the lower end of what's acceptable). Something that I noticed during this test while closely watching the cartridge from the front while it was playing is that the plastic body that holds the stylus isn't quite sitting square in the cartridge body. I wonder if there was more damage during transit than I thought and a whole new cartridge was required rather than just a new stylus? The stereo image is very slightly off centre which may or may not be a symptom of this?
DougK said:steve_1979 said:I've also discovered that the arms resonant frequency is 9Hz (which is apparently at the lower end of what's acceptable). Something that I noticed during this test while closely watching the cartridge from the front while it was playing is that the plastic body that holds the stylus isn't quite sitting square in the cartridge body. I wonder if there was more damage during transit than I thought and a whole new cartridge was required rather than just a new stylus? The stereo image is very slightly off centre which may or may not be a symptom of this?
Pioneer has roughly the same resonant frequency. How did the Techie do on the bias tracks?
Does the stylus cantilever look square to the record groove? If not, just an idea: There is a small amount of play in the tonearm/headshell slot for minor azimuth adjustment - unscrew the headshell from the arm but don't remove it from its slot, twist it in the direction required and hold it there whilst you tighten the retaining collar. This may work or not.
steve_1979 said:I'll try the adjustment you suggested soon and report back.
matt49 said:Money down the drain.
steve_1979 said:£50 for a new cartridge plus I still have old stylus as a spare for the future which is worth about £22 so I'm only about £28 down really. It's a bummer but not the end of the world.
matt49 said:steve_1979 said:£50 for a new cartridge plus I still have old stylus as a spare for the future which is worth about £22 so I'm only about £28 down really. It's a bummer but not the end of the world.
No, it's not the end of the world. It's just the beginning of the end/a slippery slope/the thin end of the wedge [insert ominous metaphor as required].
Vladimir said:matt49 said:steve_1979 said:£50 for a new cartridge plus I still have old stylus as a spare for the future which is worth about £22 so I'm only about £28 down really. It's a bummer but not the end of the world.
Are you implying that going vinyl in hi-fi is like getting a boat in personal transportation? 😀
steve_1979 said:Is that to stop the records from floating away while they're playing? I don't think it'll be necessary as I've ordered one of those new Russ Andrews Gravity Filters© to stop all those pesky gravity waves from upsetting the balance of the turntable. Nothing but the cleanest purest audiophile quality gravity for me from now on and as a bonus it works on power amplifiers too making the silences in between notes even blacker.
steve_1979 said:davedotco said:steve_1979 said:Is that to stop the records from floating away while they're playing? I don't think it'll be necessary as I've ordered one of those new Russ Andrews Gravity Filters© to stop all those pesky gravity waves from upsetting the balance of the turntable. Nothing but the cleanest purest audiophile quality gravity for me from now on and as a bonus it works on power amplifiers too making the silences in between notes even blacker.
The rotating black hole at the centre of your record will produce local gravity waves that will overwhelm anything from another solar system.
The energy of the system will increase with time (no. of rotations), eventually it will radiate at radio frequencies causing even more problems. Having a pulsar at the centre of you hi-fi setup is no laughing matter.
Do you advise using shielded cables to protect the sweet sweet music from all that radio frequency interference pouring of the record player?
p.s. Listening to a bit of Bob Marley Legend at the mo. It sounds out of this world.
Vladimir said:Are they deemed voodoo in a TT setup? I thought they are for warped records.
steve_1979 said:Does anyone have any experience with the Shure M97xE cartridge? It's Shure's best audiophile cartridge (my current M44G is a DJ one) and at £80 the price of the M97xE seems reasonable. It also looks like the aesthetics would suit the spare silver headshell that I have. My only concern is that I have no experience of mounting a cartridge and the M97 looks fiddly as hell.
I'm only half looking at the moment. The M44G seems fine for now so it won't be until late in the year or next year before I get a new one. The Denon DL-110 looks good but I can't really justify spending £150, certainly not without getting a better shelf to put the record player on first.
Al ears said:steve_1979 said:Does anyone have any experience with the Shure M97xE cartridge? It's Shure's best audiophile cartridge (my current M44G is a DJ one) and at £80 the price of the M97xE seems reasonable. It also looks like the aesthetics would suit the spare silver headshell that I have. My only concern is that I have no experience of mounting a cartridge and the M97 looks fiddly as hell.
Yes. It's a good, smooth sounding all-rounder. Good tracker too. I fitted one to my brother's deck a while back. Very good value for money.
Do you know anyone who can help you with fitting the cartridge?
