Al ears
I didn't say, and nor do I think, that an £800 turntable would need a cartridge upgrade although it could supposedly take one.
The problem with many newbies is they don't know what to expect so the idea of real quality performance will be alien to them, so will the idea of acceptable sound is as well.
What doesn't help these days is most decks coming pre-fitted with a cartridge. Yes they will do the job but some care merely adequate and others quite good.
If, in your example, the three Regas were fitted with the same cartridge would someone new to vinyl hear a discernable difference? I would suggest that if that cartridge was a £25affair probably not.
However, if you significantly upgrade that cartridge, then that along with the difference in tonearms, would probably be discernible soundwise.
The idea you have to spend over a grand is also questionable depending on where your money has actually gone component wise.
 Facebook
Facebook Instagram
Instagram
