Hi all. After a (shaky) start here, I figured I show show you all what I'm listening to, then I'll go on to talk about how exactly I got to where I am today WRT HiFi.
Here's my record deck:
It's a Phillips one, which was lying around in my grandfather's loft, so he offered it to me. Of course, I said yes, and got myself a turn table, with spare needles. It sounds reasonable, but I'm not convinced the pre-amp (NAD, quite old) is right for it. Still, vinyl has it's charms.
Speakers:
Subwoofer:
This uses a pair of 8" woofers, with a circuit to get it to 28Hz see below for details.
My amplifiers started with a single 50W/channel thing. I used it with 2 pairs of the old 3-way speakers (quite common in 2nd hand shops now). Naturally, the 2 ohm impedance meant it wasn't too happy.
After upgrading the power supply,
I've got something that will actually hit it's rated output, with reasonable amounts of distortion.
I got another of these amps (from a skip, apparently broken). So, I ugraded the power supply again, then bridged it to give over 100W into 8ohm, and that went on to power my subwoofer. I also added a Linkwitz circuit, which has an eq curve which matches the rolloff of the subwoofer, meaning I can get output to as low as I want. Neat, huh?
Anyway, the subwoofer itself was made after extensive modelling, and eventually, I came up with a 42L sealed enclosure, using 2 bass drivers. I'm 16, living with parents, so, noise transmitted through the floor had to be minimal. Most of you will know of the B&W PV1 subwoofer. Mine's based loosely on that - the box doesn't vibrate at all, even at full power.
The main speakers use full range drivers, augmented by woofers. Most of you will know that a full range driver means there's no crossover right in the middle of the speech band, and this can help the sound a great deal. Anyway, I took the crossover way out of the sensitive midrange area, so it's at 300Hz, where the 2 woofers (per side) come in.
Again, when deciding woofer placement, they needed to be near the other driver (to avoid cancellation at some frequencies), and they also needed to be one on opposite side to the other, so there's no vibration through the floor.
This left me (after more modelling) with a frequency response that looks like this:
The blue line is the full-range drivers, the red and green is the woofers. I don't know why the green one contributes more than the red at higher frequencies, but it doesn't affect the sound, so I'm not bothered.
The sound.
This set-up, costing a little under £200, will happily sound better than anything I've listened to, upto and including £1000 worth of NAD electronics and Dali speakers, and that's through a cheapy usb soundcard.
To finish off, a picture of my whole system.
Chris
PS - questions happily answered.
Speakers:
Subwoofer:
The sound.
Chris
