More Power??
Hi all
I would appreciate some input on the issue of power - watts/current in a power amp.
I am looking at getting either the Moon W7 or W8 to go with Sonus Faber Amati speakers.
W7 = 150wpc in to 8 ohms, doubling to 300wpc to 4 ohms
W8 = 250wpc to 8 and 500 wpc to 4 ohms
Amati = 4 ohm speaker.
I think the 2 amps are very similar designs, other than the increased power and I was wondering what benefits I will hear through the additional current capability.
Especially in regard to the fact that I won't always be able to listen at 'demo' volumes, whilst at home. Will I get more out of having higher power, even at a slightly reduced volume, with the additional control of the speakers?
The speakers are efficient at 92db, but I have read that they may like power when available!
Any insight or things to consider would be appreciated.
cheers
Nig
To put it simply, yes more power the better. If you think the W7 may hamper your listening pleasure at times then the W8 would be the better investment. Greater control and headroom, is their anything more!!
