Jfil said:Anyone? Thanks
Jfil said:I am considering this two systems with it's original speakers (they can be replaced in the future):
Denon D-M40
Denon Ceol Piccolo DRA-N5
Sound wise how they compare? Which one is better?
Jfil said:I can buy the ceol 100 euros cheaper and with Denon provided speakers. I am affraid of working problems with built in wifi
Jfil said:Would the amp be as good as a budget separate like Denon PMA520AE?
Jfil said:I would like to have the opporunity to upgrade at least the bundled speakers and have an amp that would sound good with some tannoy mercury v1i or q-acoustics 2010i.
Jfil said:Do you think that there will be a huge difference between q-acoustics 2010i and 2020i? Some seem to prefer the 2010i. And what about the budget Roth Oli RA1? It was rewarded five stars from Whathifi.
Jfil said:They will be used in a desk. In this case you would recommend 2010i?
