Mat for rega rp1, what height,thickness to buy?
gasolin said:
I want to upgrade the turntabel mat of my rega rp1 queen le, im just not shure of the thickness if it's 1.5mm or as i measured 2mm
Here the size is very different and not shure what height thickness to buy http://www.analogis.eu/Tuning.html
Why does it need replacing?
You can get an identical one from Rega if it's trashed or there are plenty of others at 2 to 3mm that are suitable replacements. The extra 1mm isn't going to make any difference at this level.
Deleted member 108165
It probably doesn't.... gasolin is an incurable fiddler/tweaker *biggrin* Next on the agenda will probably be phono leads....
stevebrock
183
Sorry to be dismissive but changing the mat on an RP1 isn't going to make much difference unless you get an Achromat which would be total overkill
get a better deck !
gasolin
1,410
276
19,570
Because i want one that is less static and a couple of times i had it come of when i had to turn the record, if i choose a clear one i can also better enjoy the fine artwork
I'll get my coat........ ;-)
ASK THE COMMUNITY
