Hi all,
I'm planning to buy Marantz nd8006 or na6006 , just to listen to my flac files on media server.No need a cd player at all.
However i wanted to know how are the build quality for both? Photos from marantz shows very similar pcb and components in both player. On NA6006, there's no cd player and the gap from cd player seems to be filled with more power supply capacitors than ND8006. Do you have experience on both player? Are the component quality and design same for both?
To me, they both use same type of audio grade caps from Elna and Nichicon.
Acc. to marantz specs, S/N ratio of NA6006 is better interestingly. I'm looking for best audio quality .
I attached pcb look and specs. for both devices, listed on marantz website.
Thanks for feedback.
