chebby said:
plastic penguin said:
I know you rate it against the Nait 5i...
No. At least not as an equivalent.
I don't think you are going to achieve much by ending this exercise with... "Leema amp beats £480 all-in-one" because people (including myself) will just say... "Well durrhh!"
No. Don't want a Leema v Marantz comparison, that's why I worded it such a way. I'm sure the little Marantz won't compete in outright SQ.
When I took little'un to the park in Reigate, afterwards we popped into Richer Sounds and had a quick browse. It so happened they had this Marantz - Mrs. P has been badgering me to downsize for years - playing, hooked to some Q Acoustics 2020i (?) and the size would thrill the OH.
Anyway little'un was irritable after a morning in the sun... as it happened the guy in the shop let me play with the Marantz for a while, and it sounded fine (had nothing to compare it with, though), hence the question.
I appreciate it may not control the RS6 as well as the Leema, but I generally play at low to medium levels, so shouldn't be too much of a handicap, given my 40 watt Arcams controlled the speakers well enough.
I was immensely taken by the size of it...
