After a recent spate of box swapping and general mucking about I have developed mains hum in my system - argh! I'll try to explain what I have done, its a little complicated.
I bought a Speakercraft LL-One automatic line level switch. This takes 2 line level inputs, switches between them automatically and has 1 line level output. The idea is that I can use 1 power amp for both my music and AV setup, thereby only requiring one set of front speakers.
The first input into the LL-One is my Marantz NR1602 using its Pre Out. The second input comes from a Musical Fidelity M1 SDAC using its Pre Out. These both connect to the Speakercraft LL-One.
The LL-One then outputs to a power amp, a Musical Fidelity M1 Pwr. The M1 Pwr is then connected to my front speakers. The LL-One uses the Marantz by default but will switch automatically to the M1 SDAC if it detects a signal.
This setup introduces mains hum from the front speakers. The hum sounds like a low frequency constant note.
