I have an external HDD containing all my music in AIFF format. I use BitPerfect/Fidelia/Audirvana+ to play the tracks (I'm still evaluating their pros and cons). The Mac is connected via USB cable to a USB powered ObjectiveDAC (ODAC) revision B. This was connected by RCA phono cables to the 3.5mm input of a Naim Unitiqute 2 - itself attached to a NAP 100 power amp. KEF LS50s finish the chain off.
Doing some experimenting, I took the Unitiqute (as pre-amp) out of the system and ran the RCA phono cables from the ODAC straight into the power amp - a set up that I prefer sonically. You have to be careful with volume settings on computer and tablet (for remote control), because there's no amp volume control. All of which is a bit surprising, especially as the pre-amp is often cited as the best component to upgrade if you're looking for SQ improvement.
