LPF for LFE
lussen
34
run audyssey denon1910 its say front& centre full band + surround & front height 80hz.what should i set speaker crossover freq and LPF for LFE freq setting.i found from audyssey web site say always set LPF for LFE at 120hz.denon1910+ms aviano2 front_aviano 5centre_sr ms avant903i_sub velodyne impact10 .
lussen
34
for speaker crossover ok but for lpf for lfe nothing i found from 1910 set up
JohnHolmes
31
Audyssey always sets up the crossovers wrong on my M&K 750s.
I always have to return them to 80hz, sometimes sets them at 100 or 110.
Ronald Archiebald
63
Audyssey also tends to set all speakers to 'Full Band', i.e. Large, regardless if they are bookshelf or floorstanders.
Further manual adjustments are therefore always required.
I found the best setting for my setup is to set all at small and crossover at 80HZ for rear and centre and 60Hz for the fronts. the lpf for lfe i set it 120HZ. Hope it Helps.
lussen
34
thanks for this advice.i set my speaker crossover to 80hz n lfe 120hz now im very happy with this set up
