I currently have Logitech Z-5500's and though I am very pleased with them for the price. I am now looking for an upgrade. I have considered the Onkyo 609 as the AV AMP and intend to buy it from richer sounds with the 5 year warranty because I do not trust these AV Amps with their failure rates, plus if I don't use it I can gain back the money which isn't bad.
However, I was looking at buying the Q Acoustics 2000i because they seemed pretty good for the money. However, I did want to buy from them all from the same shop (I live in Nottingham) and ideally in store rather than online because I don't want the hassle of waiting for couriers and if any problems occur, I can quickly sort it out.
But Richersounds do not sell Q Acoustics and I rang them up and they said Q Acoustics aren't that great (yeah, ok) and Monitor Audio are better (maybe, i do not know) but I would like some independant advice because obviously they will have their own agenda in place - to make me buy from their store which is perfectly understandable but it means I need to take their advice with a pinch of salt.
I think there is another retail store in the city called "Forum Hi-fi", I have not ever heard of them before but they do seem to be an official Q Acoustics stockist so I guess I could ask to have a demonstration there and then go to Richersounds right after to compare the two.
Maybe I should bring something like The dark knight to see how audio is like? I don't actually have many blu-rays to check out and I guess I can't just rip from HD audio from the net and put it on a DVD disc as I am sure it is not supported.
Anyway, what should be looking at in particular? Peter tyson seem to have a good offer on at the minute with the Q Acoustics 2000i with £60 loyalty card and some speaker cable etc but it just is that it is a courier and I am not entirely sure...
I am totally lost a bit. Would much appreciate it if you could give me any advice, I do not want to spend a fortune - I kind of just pushed for £600 speakers for the Onkyo as I originally was going to get Boston Acoustics 5.1 XS or Wharedale HCX-1 (or something like that) but I really wasn't sure about the Amp being more than the speakers.
Many thanks,
Hanman
Many thanks,
Hanman
