room acoustics needed for beginner in bedroom
It means, that in accordance to REW ideology you may turn your sub by 180 degrees from main angle position (face to listener). See mark 'invert' when simulate by control interface of code. At inverse position distance between sub PP (cone) and wall equals 0.
Reactions: hardcore_gamer29
subwoofer is facing my seat. so 0?
To achieve an according between measurements and calculations you, the first, have to determine the Power Point for your sub (with relating to LF range, because your sub may have more, than one PP), i.e. to find the coordinates set of PP inside your sub, the second, place your sub the same position at calculations like for measurements and to compare results. To realize the first step, it's strongly recommended to close the aperture of the phase invertor by soft material due to measurements, because the REW simulation method doesn't use such a feature. Only in case you subject to these conditions, hope to use REW correctly. It's important to achieve a match between calculation and measurement results within at least 75%.
ty for efforts and your time. I bought dirac live and it did well. Now i feel bass coming from walls. thank you
Reactions: basscleaner
