new subwoofer help
You seem to be doing everything right so I'm not sure what else to suggest.
I would try the PEQ adjustments in the app for sure.
Nothing wrong with the sub (as far as I can tell from a pic), that's just the join where the vinyl wrap meets. On the bottom so not visible when the sub is in situ.
Reactions: hardcore_gamer29
HI I DID CRAWL AGAIN 3RD TIME BUT THIS TIME IT WAS JUST RIGHT OF MY LEFT FRONT SPEAKER. Now the thing is that when i put sub in my siting position bass was good while was on floor but then wehn i was back at my chair bass was again not good. how is this possible? Should i put the sub on chair? i had been putting it on floor for crawl
I would put the sub on the chair (I did).
Have you tried playing some music or a movie you know well and adjusting from there?
yes i played spectre movie 4k opening scene that has deep bass. But it was not that deep . the thing is spectre has deep bass on 2nd position but my indian blurays has deepness in 1st position. Dont have any clue what to do next?
Be interesting and potentially useful to see what settings you have on the Denon. Eco mode, Dynamic Audio settings (can't remember the names off hand)
here. also tried front to 60hz 80hz and full its not blending well or bass is missing
The one that's titled Speakers/Distribution - what does that adjust (can't read the text at the bottom of that screen)?
Speakers/Crossovers needs changing from Full Range as the speakers aren't full range, and regardless of size of speakers, if you have a sub, they should be set to small.
Can't remember if Direct bypasses the sub for 2 channel music.
You have a very good multi-channel amplifier but are only using 2 channels?
i am adding slowly. First i bought denon x4800h 1.5years back then now bought sony oled then dali opticon 2 mk2 and now subwoofer
i have finally given up on this subwoofer did crawl today 4th time and put here but again when it was on chair and i was on floor bass was deep but actually its all same not that good brah...
