new subwoofer help
Set to LFE only
Bass extraction LPF - should be set to 120hz or off
Crossover needs to be 10hz above the lowest frequency your speakers can play. Usually 80hz is a good starting point.
Set to LFE only
Crossover needs to be 10hz above the lowest frequency your speakers can play. Usually 80hz is a good starting pointoff topic I have dali opticon 2 mk2 as fronts and denon x4800h and svs pb 200 pro. I am getting svs ultra evolution at 100000 INR and dali opticon vokal at 75000 INR what should i buy? Will there be much issue if i mix svs
Set to LFE only
For surround sound, tonal balance is important. Speakers from different manufacturers may have a different tone, making transitions from speaker to speaker more obvious, thus diminishing the illusion the soundtrack is trying to create.
Having speakers from one manufacturer and a sub from a different manufacturer doesn't matter.
But having different manufacturers for front, centre and rear would not be a great idea.
i can go max dali opticon vokal as dont have budget for rubicon vokal. should i proceed
The same answer applies really.
The Opticon and Rubicon are both Dali so should have a similar sound signature.
You need to hear them to be able to decide.
Budget, space, and how they interact with your room are all important considerations.
Reactions: hardcore_gamer29
