Thanks for your reccomendations guys
I've had a look at both TV's and they both seem quite good, i'm not sure which one would have the best picture out of the two.
I couldnt find many reviews for the samsung LED.
Negative points for LED ->
- Potential clouding
- Narrow viewing angles
- Glossy screen causes reflections ----- Slightly concerened about the clouding issue, not sure how regular this could be?
Negative points for Plasma ->Slightly sluggish Smart menus at timesPictures not as bright as LCD ones - not sure how much brightness would be lostStandard definition images lose a little colour naturalism ---- Slightly concerned about how much difference this would make?I would also be wanting this tv for gaming so not sure how much of a difference that makes?I know that both TV's have a motion rate of 600 Mhz.So i guess now i'm not sure which one to go for out of the two or if there are any other options out there that i should consider?Cheers
