Having lost the credit card sized remote for my Krell Showcase processor for the umpteenth time, my wife asked why she couldn't control the volume from the Sky remote. A good question.
Sky's remotes are programmable for a variety of TV makes - but you need the right setup code for the make of TV you are using. I tried searching the web for a Krell code without success, and then tried a few of the setup codes of the more common makes and got nowhere. Sometimes you can be lucky, particularly if manufacturers use the same chipset. The Sony control codes are widely used by other manufacturers.
All I want is the volume control to work - has anyone had any luck getting a sky remote (version 9) to work with a Krell?
Thanks.
Thanks.
