shkumar4963
- Nov 19, 2014
- 3
- 0
- 0
steve_1979 said:The majority of coaxial speakers that I've heard have seemed good in some areas but tend to be quite compromised in other areas. My experience of KEF speakers is quite limited but what I've heard has been very good. You certainly seem to be leading the field where coaxial speakers are concerned as the compromises that I've noticed in most them seem to be much less present in the KEF's.
You mentioned the region around the tweeter that doesn't move and the smooth trim ring that covers the basket area around the edge of the mid/woofer where it meets the enclosure. Was this easy to develop as it looks like a relatively simple idea in concept? I know how these sort of things often tend to get very complicated once you start looking at the details required to put it into practice.
Also what are your thoughts on the Genelec 8260A speakers? They seem to be the only other company that are pushing forward with development in these areas. They seem to have similar ideas to yours but have taken it a step further by effectively having an almost perfectly smooth acoustic wave guide that goes all the way from the edge of the tweeter, across the mid-range cone (which barely has any movement on the 8260A) and right to the edge of the enclosure. The results are the best that I've ever heard from a coaxial driver.
shkumar4963 said:Vladimir said:Most amps don't make an audible difference regarding sound refinement, resolution, musicality, but they sure do have differences at their primary job, amplifying a signal . And we certanly shouldn't ignore the psychological appeal from how the industrial design makes you feel, the 'tribe' you join when you buy into a hi-fi concept and the brand heritage etc.
Anyways, let's stick to the topic about speakers. *biggrin*
This is hard to believe as there is a healthy hifi amplifier industry ( manufacturers, dealers, reviewers and forums) and it is hard to sustain it without any "hearable" differences. What am I missing?
shkumar4963 said:My dealer does not allow use of A/B switch so hard to tell a difference since he takes about 10 minutes to change amplifier and my audio memory is not that good.
Native_bon said:Most popular does not mean correct. Of course in general tech has moved on in terms of sound quality. But this applies to a very small percentage. I would confidently say about only 5% the rest are just nice looking HIFI with horrible sound. To me the sound the HIFI industry promotes sounds hard, bright & disjointed.
The Future
If you relax and take a mental journey to the 22nd Century, it is easy to imagine the perfect loudspeaker. It would made of an immense number of tiny point sources that would create a true acoustic wavefront (or soundfield). Resonances due to massive drivers and cabinets would be a thing of the distant past. A host of distortions (harmonic, intermodulation, crossmodulation, frequency, phase, and group delay) would be utterly absent ... the sound would be literally as clear as air itself.
This perfect loudspeaker would be made of millions of microscopic coherent light and sound emitters, integrated with signal processing circuits all operating in parallel. (Similar in principle to present-day military phased-array radars, with tens of thousands of tiny antennas with individual electronics subsystems.)
It would be "grown" by nanotechnology and operate at the molecular level, appearing simply as a transparent film when not in operation. Let your imagination roam free ... this device also has access to all sounds and images ever recorded, and an instantaneous link to billions of similar devices. The primitive 20th Century technologies of telephones, movies, radio, television, hi-fi stereo, and the World Wide Web converge into an apparently simple technology that is transparent and invisible.
The Past
Contemporary speakers, for all of their faults, are better than most speakers of the Fifties. Very few "hi-fi nuts" had full-size Altec "Voice of the Theatre" A-7 systems, Bozak B-305's, 15" Tannoys, or Klipschorns. The typical enthusiast had to endure University, Jensen, or Electro-Voice 12" coaxial drivers in large resonant plywood boxes with a single layer of fiberglass on the rear wall. A large cutout served as the vent, resulting in boomy, resonant boxes tuned much too high, with a 6 to 12 dB peak in the 80 to 150 Hz region. (Have you ever heard a restored jukebox?)
The coax, or worse, triax drivers went into paper cone breakup at 300 Hz and above, cavity resonances (due to the horn element mounted in the cone driver) at 800 Hz and above, horn breakup throughout the working range of the short horn, and phenolic diaphragm breakup at 8 kHz and above. A "good" driver of this type usually had a plus/minus tolerance of 4 to 8 dB, and it took a lot of judicious pen damping to get it to measure that well.
It wasn’t for nothing that early hi-fi systems acquired a "boom-and-tweet" reputation. The sound quality was closer to an old neighborhood theatre, or amusement park skating rink, than a modern speaker. The tube electronics helped sweeten much of the coarseness, but they couldn't rescue the really bad loudspeakers of the day. True, the first-generation Quad, the RCA LC-1A, the Tannoy, and the Lowther compare well with modern systems ... but they were rare, and very expensive, at the time. How expensive? The classic speakers cost as much as a new Volkswagen or the down payment on a house!
Peering through the looking-glass of time, we can see that the old designers had no consistent way of modeling or predicting the bass response, and the materials available for tweeters were very poor by modern standards. Today, accurate, design-by-the-numbers bass is taken for granted, and modern tweeters really are superb.
Where modern systems fall down is midrange performance, which doesn’t lend itself to the computer design tools that are so convenient in the bass and treble range. The sparkle and dynamism of the best classic speakers is in the midrange, the most important, and yet the most challenging, part of the entire spectrum. Progress in the midrange region has been slow for many reasons.
My system is fine. Cannot be happier. Got my input trim of the AVR450 set to 4V RMS.Jota180 said:Native_bon said:Most popular does not mean correct. Of course in general tech has moved on in terms of sound quality. But this applies to a very small percentage. I would confidently say about only 5% the rest are just nice looking HIFI with horrible sound. To me the sound the HIFI industry promotes sounds hard, bright & disjointed.
You may have a large sensitivity mismatch between digital player output and amplifier input. That's not too unusual.
jackocleebrown said:We tend to do the majority of our testing on large amps that we know well. We do this so that we focus on maximising the speaker performance in an absolute sense. The danger of using a lower performance amp is that you start to tune the speaker to compensate for the character of the amp. We generally always will then do some final testing on typical partnering equipment to check there are no nasty suprises.
Kind regards, Jack.
Native_bon said:My system is fine. Cannot be happier. Got my input trim of the AVR450 set to 4V RMS.Jota180 said:Native_bon said:Most popular does not mean correct. Of course in general tech has moved on in terms of sound quality. But this applies to a very small percentage. I would confidently say about only 5% the rest are just nice looking HIFI with horrible sound. To me the sound the HIFI industry promotes sounds hard, bright & disjointed.
Jota180 said:You'll probably come back now and tell me science is astounded by your bat like ears!
Well will let others decide from your post.Jota180 said:Native_bon said:My system is fine. Cannot be happier. Got my input trim of the AVR450 set to 4V RMS.Jota180 said:Native_bon said:Most popular does not mean correct. Of course in general tech has moved on in terms of sound quality. But this applies to a very small percentage. I would confidently say about only 5% the rest are just nice looking HIFI with horrible sound. To me the sound the HIFI industry promotes sounds hard, bright & disjointed.
What we can say with absolute precision is you're now decades older and decades more decrepit! lol
Your ears have gotten pregressively worse year on year. If you work in loud environments, like concerts, ride motorcycles then even more so. You ability to hear higher frequencies is probably closer to a 90 year olds than an 11 year olds.
shkumar4963 said:I have seen that when any speaker is reviewed the first thing they do is to show you its anechoic frequency response curve. We also know that using an active equalization, one can adjust the frequency response curve upto +-6 dB or even more. There are many DSP based EQ available that can do that and there are many older passive EQ also available. Besides in room frequency response curve is much different in any case where most peorple listen to their speakers.
In this case, why so much attention to flat anechoic frequency response curve?
I had read a paper by Harmon Kardon that showed that in large listener testing the speaker with flatest anechoic frequency response curve was preferred even though all listening tests were conducted in non-anechoic conditions. What could be the reasons? I am assuming that no EQ was used in that study.
Does a speaker with a flat anechoic FR curve sound better than a speaker with poor anechoic FR curve but adjusted using active or passive EQ?
Is there a difference? Why?
steve_1979 said:shkumar4963 said:I have seen that when any speaker is reviewed the first thing they do is to show you its anechoic frequency response curve. We also know that using an active equalization, one can adjust the frequency response curve upto +-6 dB or even more. There are many DSP based EQ available that can do that and there are many older passive EQ also available. Besides in room frequency response curve is much different in any case where most peorple listen to their speakers.
I've read (although my understanding is limited) that while equalisation can be used flatten the frequency response but in doing so it will also effect the phase which as far as the sound quality is concerned it is a big trade off.
