Gazzip said:Are there not issues with metadata when using wav files? Never dealt with them so just asking?
ellisdj said:I did my own testing and thought wav sounded better. I wouldnt compress the flac even if I ripped to flac so its pointless to rip to flac in my opinion.
I am only about 500gb used on a 1tb ssd so not worried about storage
Andrewjvt said:ellisdj said:Its all about the noise my man - ssd sound better, did my own testing on that as well but not tried different ones, Just bought Samsung Evo.
You can pick them up cheaper on ebay
I'd also go SSD as no moving parts and silent
Hhd laptop I'm afraidellisdj said:If you really want me to mess you up i would say its because your ripping in jriver not dbpoweramp.
Time to start again.
Also what are you ripping to ssd or hd?
JamesMellor said:Okay this is my story and I'm sticking to it.
Mac mini lossless itunes to NAD 390 via optical compared to Sony BDP 720 connected via coax - no differance
Jriver on 30 day free trail converts libary to flac , no differance to the Sony or itunes via optical.
Switch things around use usb from Mini to NAD , I'm now listening jriver usb to nad in the room , itunes to airplay around the house.
jriver expires and I go back to itunes in the room WTF ? tiny stage, no bass and a harsh treble (this is a NAD amp remember <S>) I'm moving speakers and checking connections.
I switch back to the optical connection everything is back to fine.
This has to be the way the DAC is decoding the different inputs.
So 5 billion words later , they can sound different
ellisdj said:...Also what are you ripping to ssd or hd?
steve_1979 said:ellisdj said:...Also what are you ripping to ssd or hd?
Please don't say that you think these will sound different.
CnoEvil said:steve_1979 said:ellisdj said:...Also what are you ripping to ssd or hd?
I think they might. *diablo*
steve_1979 said:CnoEvil said:steve_1979 said:ellisdj said:...Also what are you ripping to ssd or hd?
Well you bloody would do wouldn't ya? *angel*
steve_1979 said:CnoEvil said:I preferred your other reply.... *blum3*
No you don't. *angel*
CnoEvil said:steve_1979 said:CnoEvil said:I preferred your other reply.... *blum3*
So both your replies are the same?
