JPW 510i Book Shelf
Cork Steve
Got these old speakers 2n d hand.
I am trying to bi-amp and bi-wire.
I can't get the small high frequency tweeter to wake-up.
There are no external clips. Just opened up the back and it says 'remove all clips for bi-wire'.
Do they mean the soldered link pin that I have highlighted?
Edbostan
312
157
2,070
Welcome to the forum.
Not sure, however if the tweeters are knackered removing links isn't going to help.
Can you test them?
Personally I wouldn't bother with biwiring, biamping is a different matter.
I bi-wired a pair of JPW AP2s and found the sound suffered by robbing the mid-range of transparency. Don't bother
