Itunes quality via wifi?
mindmenglish
27
1. does purchasing and downloading itunes via wifi reduce quality than a wired connection?
2. does a super slow connection effect itunes quality?
cheeseboy
245
1) no
2) if you are just downloading then no, but streaming across the internet, quite a lot of playback services have an adapative rate control. For example, if you listen to bbc radio live and it detects your internet connection is clogged up, then it will reduce the bitrate. But itunes irrc stores everything locally, so it will just take longer to download.
