Isolation Pads
🙂 Don't know what happened there, but the message got lost somewhere. Anyway what I did say that I have a Marantz PM6003/CD6003 with Monitor Audio BX2 speakers. Interconnects are Chord Crimson Plus and speaker cables are Chord Carnival Silver Screen. The sound of this set up was as good as could imagine until yesterday. I purchased Atacama speaker stand isolation gel pads for the top plate of my stands. And what a difference, both the bass and treble are much cleaner. The sound is altogether more dynamic. These isolation pads do work and they only cost £14. 95 from Superfi. The difference they make to the music is well worth the money.
Hi! :wave:
I have all my hifi system putted on these selfmade support.I use 3 of them under each components,also the speakers.If it weight 9kg max you should use these air filled rubber balls,over 10kg use the tennis balls,like I've done.Only 3 under each component.
here there's my system(all with italian description...) http://www.ilgazeboaudiofilo.com/t3223-l-impianto-di-salvscarfone-foto-aggiornate
hifi shock said:
Hi! :wave:
Well theses isolation pads look totally useless and a complete waste of time effort and money.
Oh and its important to have electrical components,,,i.e. cd players level yours is at an angle .
Unless of course you are troll posting.
the components don't touch the furniture,so they are completely isolated by that pads,and so the furniture(that is really solid...)is not a problem.I take extreme care of vibrations,I've abarthized also the inside of cd player,amplifier,I've stucked also the furniture!
Before they were putted on a dedicaded table
the table was internally build in this way:
moon said:
best not to stack components
usually I'll isolate them with balls as you can see in the photos,but surely a tuner or a cp player doesn't run hot,so there is no problem of ventilation when stacking them.Surely I'll never stack the amp
p.s.are we maybe going OT?
HiFi Shock
I think you may need help that is not available on this forum. I would try NHS Direct as a first port of call iff I were you.
:wave:
relocated said:
HiFi Shock
:wave:
my site is not a porn site,but a site where you can view photos of the inside of hifi and ht electronics.I've read this "slang" in other forums,so I used it.I want to change the title of the relative 3d like my sign,but I don't know how to do it! :help:
relocated said:
HiFi Shock
:wave:
