Andrewjvt said:insider9 said:... and don't know what role these play to improve sound quality. Could someone please point me to an article or explain? I understand the importance when it comes to turntables but not sure how it could matter with an amp. Thanks
Turn tables yes Speaker yes
Amps? Snake oil or placebophile
seemorebtts said:Everything in your system is vibrating.amp CD wires power cable Speaker wire everything.so using isolation feet you stop most of the vibration and Less distortion but sometimes this might make it worse depending how you like your music.im trying isolation on everything to see what it sounds like.i think what ellisdj said is spot on.you need to find a balance and I'm very excited how this is changing my listing experience
do you think that i should try more expensive ones as mine are probably the cheapest IV had that actually make a differenceellisdj said:seemorebtts said:Everything in your system is vibrating.amp CD wires power cable Speaker wire everything.so using isolation feet you stop most of the vibration and Less distortion but sometimes this might make it worse depending how you like your music.im trying isolation on everything to see what it sounds like.i think what ellisdj said is spot on.you need to find a balance and I'm very excited how this is changing my listing experience
You dont need a balance - good isolators will let you hear what your kit and setup is really doing.
In reality that might not be as good as one hopes so fluffing it over a bit might be a good thing.
I.e fat on your bass might help with a leaner sound.
There is only one right and wrong with this though really.
seemorebtts said:do you think that i should try more expensive ones as mine are probably the cheapest IV had that actually make a differenceellisdj said:seemorebtts said:Everything in your system is vibrating.amp CD wires power cable Speaker wire everything.so using isolation feet you stop most of the vibration and Less distortion but sometimes this might make it worse depending how you like your music.im trying isolation on everything to see what it sounds like.i think what ellisdj said is spot on.you need to find a balance and I'm very excited how this is changing my listing experience
Hi,drummerman said:I still don't understand how a cone or spike could couple anything in a way that aids vibration reduction? As a piercing devise yes.
You can shift vibrations to different frequencies in a variety of ways and you can use materials to convert them into heat or gradually decrease them but how does having one end sharp or pointy do anything?
Are there any industrial examples of spikes/cones being used to couple things in order to reduce or redirect vibration?
I am trying to think of something that has air borne vibration issues and uses this technique (other than hifi) but struggle.
shadders said:Hi,drummerman said:I still don't understand how a cone or spike could couple anything in a way that aids vibration reduction? As a piercing devise yes.
Not a mechanical engineer, but spikes reduce the contact area from the speaker to the floor, and hence less energy transferred to the floor. This would be my understanding.
Regards,
Shadders.
drummerman said:shadders said:Hi,drummerman said:I still don't understand how a cone or spike could couple anything in a way that aids vibration reduction? As a piercing devise yes.
Regards,
Shadders.
According to some here cones or spikes are supposed to be used for 'air borne' vibration ie. sound waves from speakers.
I don't understand the concept of how coupling via the above would do anything.
In my previous post I've outlined methods of reducing vibrations. I just can't see how a single material cone would help.
There are more complex, mixed material ones but some Sorbothane would probably do a better job and it still doesn't explain why a cone or spike shape would be beneficial.
Like I said are there any examples other than hifi which may help me understand?
Townshend clearly demonstrated the effectiveness of his seismic sinks with accelerometers at shows and I can understand the principle but having difficulty with the cone spike thing?
andyjm said:drummerman said:shadders said:Hi,drummerman said:I still don't understand how a cone or spike could couple anything in a way that aids vibration reduction? As a piercing devise yes.
Regards,
Shadders.
By 'coupling' a device to a solid shelf or wall or floor you are effectively increasing the mass of the device (to make an amp rattle that is tightly coupled to a wall, you need to rattle the wall as well as the amp, and given the mass of the wall, that is much harder). You could bolt the amp to the wall/shelf/floor or you could opt for a high friction fixing that keeps the amp stationary relative to the wall/shelf/floor. Spikes create high contact pressures at their tip, and tightly couple the amp to the support.
drummerman said:That is exactly what I dont get. Is there any evidence that these tiny surface points of a cone or spike actually increase coupling?
I get bolting, glueing or even using Bluetack to couple something but simply dont understand why the cone has been chosen by the Hifi Industry and not many other places (or are there others)??
andyjm said:drummerman said:That is exactly what I dont get. Is there any evidence that these tiny surface points of a cone or spike actually increase coupling?
Spiked shoes, studded tyres, crampons for walking on ice, all examples of increasing the contact pressure at a small point as opposed to spreading it over a larger surface area.
andyjm said:The capacitors and resistors found in HiFi equipment are microphonic, but these days with small surface mount components stuck onto a rigid board, the effects are probably inaudible.
A quick way to check:
1. Put your CD player on pause.
2. Turn the volume way, way up
3. Tap each device in the signal chain with the end of a pencil. A 'boing' out the speaker indicates the device has microphonic components in it and possibly some sort of acoustic feet might make a difference. No 'boing' (and there probably won't be), then any money you have spent on feet will have been wasted, and I am afraid any improvement you have heard is just suggestion bias.
Hi,Gazzip said:andyjm said:The capacitors and resistors found in HiFi equipment are microphonic, but these days with small surface mount components stuck onto a rigid board, the effects are probably inaudible.
I would have thought that the materials used to make the capacitors, resistors and even the rigid circuit board inside our electronics would each have their own acoustic resonant frequency. This could be down in the 20Hz region and below or right up in to the KHz region and beyond, and could potentially create a microphonic effect through self-vibration at their given resonant frequency. (Look up Tacoma Narrows on YouTube for an dramatic example of resonant frequency)
Tapping a pencil on your kit isn't going to expose it to the full range of frequencies that a loudspeaker can produce, but playing recorded music will. Stillpoints, and the Cera-Discs which ellisdj has recommended, work on the principle that your hifi rack will isolate your kit from the room and prevent vibration entering your kit from the floor up. I think that Stillpoints and Cera-Discs are intended to drain any airborne induced vibration out of your kit and in to your stand. This is why really good stands have a frame which isolates and shelves which act as dissipators to allow the kit to drain vibrations away. The Stillpoints/CeraDiscs simply assist the rack in doing its job.
I have bought a couple of sets of CeraDiscs on ellisdj's recommendation and I am very happy with them under my DAC and valve amplifier. DAC's are full of sensitive oscillators don't forget...
Ellisdj is costing me a lot of money at the moment! *biggrin*
shadders said:Hi,Gazzip said:andyjm said:The capacitors and resistors found in HiFi equipment are microphonic, but these days with small surface mount components stuck onto a rigid board, the effects are probably inaudible.
While you are all at it - have a look at these :
"http://tianderen.blogspot.co.uk/2009/08/fengshui-and-hi-fi-system.html"
"http://desirableaudio.blogspot.co.uk/2009/02/hifi-feng-shui.html"
And if you really want to get with it, then why not try :
http://www.harekrishna.com/col/philo/
Crystals help too, apparently, although you may need a feng shui consultants help on where to stick them....
Regards,
Shadders.
Hi,Gazzip said:shadders said:Hi,Gazzip said:andyjm said:The capacitors and resistors found in HiFi equipment are microphonic, but these days with small surface mount components stuck onto a rigid board, the effects are probably inaudible.
Regards,
Shadders.
Hi Shadders, Very helpful. However I would prefer to stop the chassis containing my microphonic electronic components from vibrating.
Gazzip said:Ellisdj is costing me a lot of money at the moment! *biggrin*
shadders said:Hi,Gazzip said:shadders said:Hi,Gazzip said:andyjm said:The capacitors and resistors found in HiFi equipment are microphonic, but these days with small surface mount components stuck onto a rigid board, the effects are probably inaudible.
Regards,
Shadders.
Is that perchance, a euphemistic sentence?
Regards,
Shadders
i can't seem to find them online how much are they anyway CeraDiscsGazzip said:andyjm said:The capacitors and resistors found in HiFi equipment are microphonic, but these days with small surface mount components stuck onto a rigid board, the effects are probably inaudible.
ellisdj said:www.plinth-design.com -If you look at this site - look down to the item called Cera-Disc - that is the product I helped develop.
Q5 said:ellisdj said:www.plinth-design.com -If you look at this site - look down to the item called Cera-Disc - that is the product I helped develop.
Scroll to the bottom of the page - £148 for 4
