ellisdj said:davedotco said:radiorog said:Great point. Can you answer this Dave?lindsayt said:davedotco said:Sighted testing is meaningles other than for a bit of fun and a get together of like minded enthusiasts.
Enjoy yourselves and have some fun, do tell us all about it, for entertainment value only, of course.
I disagree totally.
I'm sure the vast majority of people reading this chose their systems (or chose to keep them) on the basis of sighted tests.
Are you saying that their (and quite possibly your) tests were meaningless? Even though that's all that was used to decide what to buy and keep?
If someone has integrity I am quite happy to accept the results of their sighted tests. Even more so if they have similar tastes to me and a proven track record.
Listening and enjoying music on you hi-fi is fundamentally different, it invoves evaluating how a system works together, how well it meets your requirements for the reproduction of recorded music and how it interacts with you, the listener. Your ears and your brain are a fundamental part of this 'evaluation', how can they be otherwise?
This is not the same as determining whether a cable does or does not effect the sound. This is a single simple evaluation, is there a difference or is there not. When attempting evaluations of this type it is standard scientific method to only change one variable at a time and to make a judgement without knowing which of the items is under test on each occassion.
Not the same thing at all.
Even this is wrong.
Harmon say that to test anything in sound at all it needs to be in mono only - so its not how things work together its how things work in isolation - single speaker only
So any blind testing linked to by anyone in any thread so far unless it has been done with a single speaker (dont remember any seeing any) - under the extreme conditions Harmon use its fundamentally flawed.
So if anyone is about to link the same crap again dont bother its just as flawed as me going round someones house to listen.
So unless a test can be done under the conditions Harmon do - then you might as well not bother - you might as well just do as everyone else does just sit and listen, because even though you think you have proved something, you havent conclusively.
Your understanding is at fault. The Harman engineering department is one of the most sophisticated in the world of hi-fi. It is used to test individual components and to reference what is heard to what is measured, they do not and will not make any attempt to evaluate a system with respect to 'enjoyment' or 'musicality'.
They also 'train' their listeners to detect differences and to evaluate their products in terms of 'improvements' and yes they do much of their listening in mono. Their tests are carried out using techniques that are scientifically correct and give results that are consistent and repeatable.
About as far from an informal sighted test as it is possible to get. Totally irrelevant in this context.
