- Aug 10, 2019
- 2,556
- 5
- 0
Im going to install wall speakers, so i need to sink the speaker cables into the walls, im gonna use an angle grinder to cut in and im using Qed anniversary XT cables, what i was going to do is cut a thin channel about 5-7mm push the cable in and use filler to fill it, but i was wondering will the moisture from the filler damage the speaker cable,
Anybody have any better ideas.
