DandyCobalt said:Peter from Alternative Audio recommended that, as I'm going the moving coil route, then the signal path would benefit from being as good as possible - ie, use a better cartridge-to-amp wiring than came with the original p3.
So after a bit of research, and a bit of advice on options from Analogue Seduction, this is the rewire I've gone for...
http://www.ebay.co.uk/itm/ws/eBayISAPI.dll?ViewItem&item=390400707889&ssPageName=ADME:X:RTQ:GB:1123
It's an all-in-one, single cable reach from cartridge to amp, with a separate grounding wire (I understand that the Rega originally grounds through one of the L/R channels?)
I'll do the rewire before getting the new cartridge, so that I can check any differences step by step.
The subplatter is still running-in ...I turned it off overnight, but then started it again before heading in to work (my patience surprises me this time 🙂
I've also bought some Isokinetic shims, just in case the new Benz cartridge needs more height (VTA) than the Goldring 1042 did - any heads-up advice on this last point most welcome.
Dandy . . . I'm getting :bounce: . . .
Interested in the rewire results, especially what it might do for the Goldring? I'm not one for silver cable . . . but, ever the open mind, I look forward to your comments?
As for shims, I presumed these would be fitted by 'Peter'? Sounds like he is leaving it to you? Any-old-how, the criteria I worked with was that the Rega VTA geometry is designed to work with their 15mm standard cartridge height. I think the Goldring is 17.5mm? . . . I have no idea what the Glider is, probably be in the instructions . . . I would guess, 18mm? There may also be some guidance on the arm height at pivot point; arm parallel, high, low?
Its a faff, takes time, experience has taught me dont assume just because the difference between 15 and 18mm is three . . . god I'm running hot this morning:bounce: 🙂 . . . that you will require 3mm of shim. That difference, although correct, was too much for me, I listened, changed shims, listened again etc. Tedious, worrying as the cartridge is vulnerable every time you remove the arm . . . I eventually settled on 1mm of shim, visually, my cartridge body runs parallel to the record . . . it is18mm high . . . so, its suck it and see.
Took me a couple of shimming sessions, the initial one, to get it sounding OK . . . then after a few hours of the cartridge settling into my system, (you will need a lot more time running it in) and me liking/disliking various tracks, I was able to be more specific and settled on +1mm.
Over many hours playing time, the sound is getting sweeter, this I put down to the settling of various components and adjustments I have made, like main bearing/sub, cartridge VTA, cartridge stylus pressure, arm bias.
Get comfortable with the sound, me being me, after that first few hours of adjust, listen and adjust process. I found, after a few more hours, I was able to fine tune the stylus pressure and arm bias to an even sweeter point of focus. Reducing down force by tiny, tiny amounts, the bias is now almost zero as well. These minute adjustments, some would say, are pedantic . . . to my ears they are significant and important to the final performance I hear.
I can be(am?) ultra-fussy, so you have to decide where you are happy to stop? . . . but in my opinion, my fussiness has paid dividends by the bucket full, 'extracting so much from so little'.
CJSF
 Facebook
Facebook Instagram
Instagram
