Turntable upgrade
trebor1594
Hi Guys n dolls
So i want to upgrade my TT . Currently its a Rega 1 with a Rega 220 tonearm -a Rega 2/3 glass platter and an ortofon blue cartridge . I keep looking at Linn lp12.s on Ebay -such a lot of different specs - or should i just go for a modern TT ? Im looking to spend around £2000 .
Im using a Rega mk 3 phono amp at the moment -so may have to figure in a new pre amp if i want MC ability . Music i listen to is varied but no classical or jazz .
Hi Guys n dolls
Second hand LP12s can be a nightmare, steer clear unless buying from a dealer near you that you can pick up yourself. For that sort of money I would go for new.
Reactions: spl84 and DougK1
trebor1594
Hi - yep im thinking thats the best plan -just keep going round and round with all the reviews . Has anyone got any experience with the Planar 8 ?
daytona600
Linn rabbit hole is 50years old with " new " versions every few month
IMHO New 21st designs Project , Technics , Rega
SL1200GR2 , P6 or X8
Reactions: nopiano and Al ears
trebor1594
If you like that linn lp12 look, but don't need the hassle....then maybe have a look at the pro-ject Classic evo...that's probably what I'd have went for if the Avid ingenium hadn't impressed me so much a couple of years back.
Thats brilliant . I hadnt been looking at the Project range as i thought they were mostly budget models . I really like the look of that and it allows me to factor in a better pre-amp . Thankyou very much for that suggestion kind sir !
Reactions: skinnypuppy71
daytona600
£10,000 for the bigger ones , £15,000 complete with phono stage & cartridge
New Signature 12.2. Over 80 lbs. of mass and 100+ high-precision CNC-machined parts comprise this masterpiece. All manufacturing is done in-house at the Pro-Ject factory in Europe , keeping costs down and passing savings along to serious vinyl enthusiasts
trebor1594
As are the vast majority of turntables.
Your point is???
Just a wry comment Alears - you can spend as you have shown -a fortune on a TT but if the " drive belt" stretches it all goes to pot !! Much cheaper to resolve than having to replace bearings etc in a direct drive system . The twin camshafts in my car engine are also rotated by a belt - but if that fails your are in big trouble .
Should have got a car with chain drive... :)
Point taken but belt stretch is uncommon unless it's really old or abused and a lot cheaper to fix than any electronics utilised in a direct drive. These are expensive to make anyway, in comparison, if it is done to good effect.
Nothing against direct drive mind you as I have owned at least one in the past.
Reactions: DougK1
