Input lag on a SamsungUE46c8000 will i notice any input lag on gaming?
Having read the exellent 3D supertest today in Decembers issue i love the sound and looks of the sammy set but there isnt any mention of input lag on any of the sets tested.also am considering the Sony46HX903 , i will be doing a fair bit of gaming ie FIFA GT5 when its finally released!!!
Can anyone give any advice thanks .
general viewing has VERY bad lag
Gaming mode goes down to 32ms (not bad). BUT, this is specifically on 1080P/60 mode. 720P (must be due to scaling) has worse lag
As most games run at 720P and your specifically wanting it for gaming, id pass
So what would you recommend alienRIK? bearing i mind im looking at a 3d capable 46 inch set.
As you state it must be 46", the sony KDL46HX803 is probably your best bet (using GAME mode for gaming)
Lag on a monitor only makes up a small amount of the input lag on computer game.
A prominant technical hardware site makes the following analysis on input lag
General lag is typically made up of
controller 8ms
Cpu 20ms
Gpu 33ms
Frame Transmisson 16 ms
Double Buffer Sync 16ms
Monitor lag 32 ms
Total 125ms
As u can see montor lag is only a small percentage and an increase in 10% monitor lag doesnt add up to that large an overall input lag increase (3%)
A Samsung Ue46C8000 has an input lag of @32ms in game mode. There is no problem playing either single player or multiplayer games on it.
edsib1:
Unfortunately, all 720P content is higher than 32ms(Which is borderline to begin with)
And anyone with a faster tv will have an advantage playing online games
Not to mention the rest of those statistics are generally meaningless
Those figures come from probably the most highly regarded tech site out there...
The Samsung & Sony have practically the same input lag (32,31).
As I pointed out lag on the monitor is only part of the picture. I'd be more concerned with network latency when playing online games.
edsib1:
Whats the lag for the samsung displaying 720P content?
