tonky said:Makes for very interesting reading. The Behringer A500 - is that 200£ approx - any uk stockists? . I know it doesn't look fantastic - but it looks well worth a punt on "sound per pound"
tonky
davedotco said:For me, the issue remains the cost of the power supply, which I and many others consider pivotal to the performance of amplifiers, it has been suggested that for music reproduction a big power supply is un-necessary due to the transient nature of the music signal.
There is some logic in this argument but it goes against all the empirical data that I have accumulated over many years in and around this business and in this case i think the logic is flawed.
Vladimir said:We are talking what makes some amplifiers better than others. Build quality and application range both factor prices. The A500 completely represents this logic because it trades build quality for a slightly wider application range and very low price due to economy of scale. You can't do EoS with high build quality. If your amplifier has expensive japanese components, fully regulated PSU, power to deal with 1ohm loads at high SPL in large living rooms, all input facilities and appealing aesthetics, that will certanly not cost 140 quid, even when made by Behringer.
There are no real bargains in business. At best case scenario you get what you paid for.
FennerMachine said:Hi Vladimir and davedotco (and anyone else who wants to answer this specifically).
Would you consider Icon Audio ST40 MKIIm at £1700.00 to be a well engineered amplifier, and is it worth spending that sort on money? What solid state amplifiers would perform the same/similar but perhaps cost much less?
Vladimir said:Budget integrateds with their 250VA-350VA transformers powering everything onboard are certanly pushing the envelope in transient peakes. Big caps will solve a large transient but if the amp is discharging energy from the caps faster than the rectifier bridge and transformer can catch up, the PSU will sag in such peaks. You may hear it, you may not, depends on application and level of abuse such as speaker load, desired SPL and type of music.
The manufacturer cannot predict what you might do to their amplifier. If they over-eingineer it for all sorts of abuse, it will cost a pretty penny. If they aim at profitable yet VFM budget minded prices, they will average things out by presuming you will listen to Norah Jones through 89dB/8ohm speakers in a small room no louder than 85dB at listening position. If you bought a Rega Brio-R for pumping out D'n'B with 84dB Bowers' in your 50sq.ft. living room at 95dB continuous SPL, the blame is on you.
BTW why is everyone under impressions the A500 is some pillar of endless power for cheap? It is 125W in 8ohms at 1% THD. It weighs 8.8kg, built with lowest bottom of the bin PRC generic components. I wouldn't recommend it to anyone unless they are desperate to throw a party this weekend for cheap.
Those 125W (at clipping, no headroom left) are insufficient for large transient peaks that can go from 10W continous to peak 600W in a split second. This is not a powerfull amplifier by any standard and should be used with its performance margins in mind. It will not power all hi-fi speakers like a boss. Far from it.
Fully regulated power supplies built to last and survive most speakers and most applications do not come cheap.
SteveR750 said:Vladimir said:Budget integrateds with their 250VA-350VA transformers powering everything onboard are certanly pushing the envelope in transient peakes. Big caps will solve a large transient but if the amp is discharging energy from the caps faster than the rectifier bridge and transformer can catch up, the PSU will sag in such peaks. You may hear it, you may not, depends on application and level of abuse such as speaker load, desired SPL and type of music.
You're not the only one with this view of it, though the other reviews are as guilty of misguidedly believing they have a sonic giant killer bargain as those that spend thousands and thousands. It doesn't even increase its power output into a 4 ohm load, let alone double it.
SteveR750 said:matt49 said:Are we talking about the same amp here?
Behringer A500.
FennerMachine said:SteveR750!
What are your thoughts on Icon Audio ST40?
Feel free to say what you think, positive or negative.
Power handling (watts): 125 watts (continuous programme)
Recommended amp power (watts): 40 - 200 watts
Sensitivity (dB): 88
Nominal impedance (ohms): 6
Frequency response (Hz): 35 - 28,000
