Question How well positioned are your loudspeakers?
I have considered recently with the help of many of you on this forum.
The speakers and the listening point form an equilateral triangle with each side measuring 3 meters.
Slightly oriented to the listening point.
Side pic to show the 50cm between speakers and wall. This is for the moment the best distance to my ears. Things can maybe be improved.
One easy and free improvement has been the positioning of power supplies far from the TT.
The amp is 40cm far from the TT. The streamer and its power supply are a bit closer but I have noticed a real improvement with the heed power supply on another shelf.
Nice looking room. The most important thing is they sound good to you. You can measure all you want, but its the small tweaks that make the difference.
Reactions: BenWatts
Probably as good as its going to get as long as you use them with the TV, and the TV is in that position. The only problem with not using them with the TV, is TV speakers are useless!
I've got holidays owing so I might just take a week off and get on with making a wall mounted shelf for all the Hifi gear. It's been 20 plus years since we moved into this house, I'm not as nimble as I was, so crawling around under the floor to reroute the speaker cables is going to be fun.
