AnotherJoe said:As I''ve said if you use CERTIFIED cables they wont make a difference.
fr0g said:michael hoy said:I have been using the Chord active cables for a long time 2x 3m and 1x 2m and am extremely happy with them.
I did have a HDMI cable a while ago that truly irritated me with the way it changed the colours when in use.
Swapped it between different devices along with a different cable, the same cable changed the colours no matter what device it was plugged into.
The colours became more vibrant but not in a good way.
So I do believe cables make a difference, and good luck with the Chord cables.
Sounds like a faulty cable. A non faulty HDMI cable will look and sound the same as any other non-faulty cable. Just like the moon is in fact smaller than the sun.
duaplex said:For years I have argued how the cheap HDMI cable was no different to an expensive version.
However, today at the Bristol show I purchase 3 Chord Active Silver cables and it totally blew me away. For bluray playback or fir anything where data is being read actively from a disc, there is a massive boost in sound quality, the sound was sharper, crisp and punchier. Picture was also warmer, deeper in colour and rich. I am still reeling from the shock, I fully expected there to be no difference and to a certain degree I was right... Using it with sky, no difference, PC, no difference. However, bluray yes, music yes and even gaming.
My wife walked in and said "the tv looks better and sounds better". She was unaware of the test I was conducting, so that was unbiased from a non audiophile/videophile.
michael hoy said:fr0g said:michael hoy said:I have been using the Chord active cables for a long time 2x 3m and 1x 2m and am extremely happy with them.
The cable was not faulty, from a technical point of view.
Alec said:It's rated by What HiFi because:
"Pictures are more stable and motion more assured, while even colours are a little more vivid and exact. Sound has more scale and detail, too."
Which is cobblers, of course.
Alec said:michael hoy said:fr0g said:michael hoy said:I have been using the Chord active cables for a long time 2x 3m and 1x 2m and am extremely happy with them.
What does this mean?
michael hoy said:Alec said:michael hoy said:fr0g said:michael hoy said:I have been using the Chord active cables for a long time 2x 3m and 1x 2m and am extremely happy with them.
Exactly that, physically the cable was not faulty and met the technical spec for it to be certified.
In use it exhibited the issues (to me) i stated.
hammill said:Can someone explain why this cable has a chip in it? It might be a reason that the picture / sound are different, though I can't immediately think of why it would be necessary.
duaplex said:It's a noise cancelling chip.
iceman16 said:duaplex said:For years I have argued how the cheap HDMI cable was no different to an expensive version.
Hi..Do you realy have to care what other people(unbelievers) say? It's your own hard earned money and ears that enjoys.🙂
Thanks BB. So not required on a normal length cable, another con.bigboss said:hammill said:Can someone explain why this cable has a chip in it? It might be a reason that the picture / sound are different, though I can't immediately think of why it would be necessary.
No, the chip is meant to boost signal.
http://reviews.cnet.com/8301-33199_7-57540275-221/still-more-reasons-why-all-hdmi-cable-are-the-same/
Sliced Bread said:OK here’s a question: Let us say that HDMI certified cables are measured to less than 1-bit per billion. I am *assuming* that this is measured under the most flattering conditions possible for the cable (i.e. virtually no interference) as the manufacturer wants the certification. Does a cable that had exactly a 1-bit per billion error rate, have exactly the same error rate when stuffed under the hi-fi rack, curled up and crossing several power cables, a power block, speaker cables and interconnects many many times over in very close proximity as most of us stuff the cables out of site. I’m not sure how interference effects the signal of a HDMI cable, but it is likely that it will increase the error rates *another assumption*. *If* true then better insolation / booster chips etc may make a difference for some people, *if* their system is revealing enough *and* there are issues of interference. This is more a question than a statement.
