- Jan 1, 2014
- 215
- 0
- 0
ellisdj said:You keep saying 110db - you do know pretty much only the best subs you can buy put out 110db in a range worthy of note.
For example - the SB13Ultra works to about 95db flat to 30hz - it will go higher but then compression limits kick in.
That extra 10db is so hard to achieve its the equivalent of 2 Sb13 Ultras - but put 2 of them in your room you will know about it.
I would forget the 110db test for now - and concentrate on other things. Like going to hear a system with dual subs at the front and see if its for you / what you are looking for. Take the time while yuo pay off your TV wisely - and putting it up on the wall will the best thing you ever do - its much better up on the wall.
ellisdj said:Dual subs is not just about more bass, it can increase the amount of bass in a certain range I. E.lower freq. It will give more headroom for the big bang moments It allows more flexibility for setup and can improve freq response and make a larger sweets pot.
RobinKidderminster said:An antimode may be of interest to you too.
nugget2014 said:i was speaking to someone from svs today
Son_of_SJ said:nugget2014 said:i was speaking to someone from svs today
Would that have been Ed Mullen, by any chance? If so, he really knows his stuff.
bigboss said:Yes you can run different subs, but you will need to manually adjust them to match. Otherwise, if one sub is more powerful than the other, you will notice the mismatch. An antimode is an excellent shout.
ellisdj said:all an antimode does is in the name it will reduce room induced bass peaks it wont give you automatically amazing bass dude just bear that in mind. Not saying its a bad unit they are good units just factor that in when buying.
You want huge bone rattling bass - you need either lots of cone surface ideally then plenty of power to allow the sub to extend the bass in a small box. Thats why dual opposed 15inch drivers in the one box is so appealing i.e. Arendal it has huge cone surface area making it a very efficient design for its power
ideal av said:if i`ve read this correct, as your only in Sheffield you should have a listen to the JL subs as has aleady been suggested, you don`t need 2 subs to acheive good bass, dual subs will, if setup properly give you a flatter inroom response and help pressurise the larger rooms
to get good bass you need a good sub,,,,,, simples, but the best of subs in a difficult room will need help of some kind or another, usually positioning and eq integration goes a long way
subs are a very personal item of your av system, some people like loud thunderous bass that bends your bones, some like the often referred to as "chest slam", others like a clean sounding tight but musical bass, its difficult to get all this from a single sub so having a demo is very recommended
have a read of this SoundStage! Access | SoundStageAccess.com (GoodSound.com)
thanks for the mention guys as well, its appreciated
Allan
Series1boy said:i`m in Sheffield, and the only decent audio shops is Sevenoaks and audio images and not sure they have an atmos demo...
