How tight should the torx bolts be on my BR speakers?
Paul.
745
55
18,970
Hi all,
I have read a number of times that after a few years, it's a good idea to tighten up the torx bolts on my MA BR5s. On closer inspection, I noticed all the bolts were poking out varying amounts. Since I was in doubt about the correct torque, I used the short end of the torx key to tighten the bolts. There was no satisfying 'end' to the thread, they didn't get noticeably tighter. I stopped as I was worried about threading them.
Has anyone done this? How far did you go? Is their a torque figure anywhere?
Paul Hobbs said:
Hi all, I have read a number of times that after a few years, it's a good idea to tighten up the torx bolts on my MA BR5s. On closer inspection, I noticed all the bolts were poking out varying amounts. Since I was in doubt about the correct torque, I used the short end of the torx key to tighten the bolts. There was no satisfying 'end' to the thread, they didn't get noticeably tighter. I stopped as I was worried about threading them. Has anyone done this? How far did you go? Is their a torque figure anywhere?
Finger tight using the long end of the key into the bolts should do it.
