How much difference is there, in truth?
matthewpiano
Many of us have bought into the 'seperates are best' mantra and, at one time, I could say with some confidence that this is correct. However, is it still the case?
At the budget level there is competition from some very capable all-in-one units like the Denon RCD-M39DAB, Onkyo CR-N755, Marantz M-CR603, and the Denon CEOL range. Are these really so very far off the performance of budget seperates like the 6004 series, especially when used at acceptable domestic volume levels? Do the added features of some of these systems outweight any slight difference in sound, giving easy access to a wealth of music via DAB, internet radio, CD, Spotify and others?
Like-wise at a higher price level, is there really much advantage to buying seperates instead of a Naim Uniti, UnitiQute or a pair of AVI speakers (and yes, I know these are a quite different proposition)?
Maybe technology now enables us to enjoy the music more easily without a plethora of big 430mm boxes taking over the living space. What do you think?
Overdose
279
I believe that the differences between most audio equipment is not as great as many would imagine. I have seen various articles where very cheap equipment was indistinguishable from much more expensive set ups in blind testing to confirm as much, but then my personal reasons for buying a piece of audio equipment, are not entirely for audio quality, but also for a variety of other reasons. I suspect that this is the same for most of us.
I also don't enjoy my music any less when listening to it on any device other than my ADMs, beit car audio, headphones or kitchen mini system.
bluebrazil
19
well most cd players and tuners are fairly empty boxes with a footprint to match the amp. a pair of hard to drive speakers will always need something chunky to drive them though. the all in one is a very tempting proposition and if did not already have what i have now i would get something like a uniti and pair it with some suitable speakers.
stevebrock
183
+1
I agree, I really enjoy my system - have no intention of changing it apart from upgrading my speakers.
If I knew what I know now 18mths ago I would of probably gone for a Naim all-in-one with a pair of RS3s.
I stumbled upon vinyl by accident, I discovered the loudness wars and how the CD format is compressed & poorly mastered!
Cypher
156
Well, I have a Pioneer A-30 amp, a Beresford Caiman DAC and my source is my PC.
I was very dissapointed when I had the Marantz M-CR603 here for a while. My pioneer A-30/Beresford DAC sounds so much better. No comparison.
Just my opinion though.
T
the record spot
No surprise coming from me, but the Onkyo TX8050 is easily up there. Lovely amp that delivers form and function in one unit. Sound quality is excellent and I've been unfailingly impressed by it in the 18 months I've had it. As good as any separates set up that I've had.
abacus
The biggest difference is made by the speakers, the more expensive and the more accurate they are the more they will show up problems in other components that cheaper speakers don’t , therefore you have to get a balanced (And matched) system to give the best sound.
NOTE: Just because you have expensive speakers doesn’t mean you have to have an expensive amp (And vice versa) so long as they complement each other and give a realistic sound.
As always have a listen to various combinations that are within your budget, and buy what you like the best, then forget about anything else and just enjoy the music. (Too many Hi Fi Nuts chase after perfection rather than enjoying the music)
Hope this helps
Bill
chebby
1,253
26
19,220
"How much difference is there, in truth?"
Nowhere near as much as I expected.
Two years on and I don't miss anything about seperates.
I might buy the new M-CR610 when it emerges later in the year (because it will have one two extra bits n bobs) but it will have to be at least as good as the '603.
Instead of buying a Denon CEOL Piccolo for a second system (with my JPW Sonatas in the spare room) I will use my old M-CR603 instead.
Given a little more financial latitude/luck that would read "Naim UnitiQute" instead of "M-CR610". (But not seperates).
John Duncan
None of any note, when comparing like with like. The Uniti is one of the best sounding things I've had in the house, and whilst it was bettered by the SuperUniti, you might expect that given their relative costs.
I certainly don't get anxious about whether things are in one box or not, I get more anxious about whether they look good :)
chebby
1,253
26
19,220
John Duncan said:
None of any note, when comparing like with like. The Uniti is one of the best sounding things I've had in the house, and whilst it was bettered by the SuperUniti, you might expect that given their relative costs. I certainly don't get anxious about whether things are in one box or not, I get more anxious about whether they look good :)
... and one Naim box looks three times better than three Naim boxes.
andyjm
15
There are very good technical reasons for keeping the DAC and the digital source in the same box. The S/PDIF interface had known limitations at birth, and that was over 30 years ago. So, at the very least, have your streamer or CDP co located with the DAC - which raises very good questions about the fashion for DACs in separate boxes.
The circuit board real estate taken up by streamers, DACs, (and now even amps, if class D) is tiny. Why buy large empty boxes and string them together with cables? I am a firm believer that the future is fully DSP active speakers with all the electronics, wifi, streamer, DSP, class D amps all in the same box.
When you last bought a car, did you buy the engine separately from the body and install it yourself?
Don't think there is a cavernous difference as there once was. Many all-in-ones perform better than the sum of their parts. That said, I've not heard huge number of all-in-ones.
Above all else, it boils down to which ones you feel most comfortable with, I suppose.
chebby
1,253
26
19,220
I am with you there. I think B&W are ahead of the game in this respect. (Having heard their A7 and the little Z2, I am hoping to see an 'A9' or a larger, more fully featured, 'Z' model one day.)
richardw42
299
are the Marantz & Unitiqute quite different things.
The Marantz has cd & airplay, does the Naim have airplay now ?
ID.
207
When I bought my Esdoteric RZ-1 I wasl also listening to the Marantz PM15S2 and matching CD player. The prices were similar and I thought the difference in performance was negliible. Maybe an extensive home audition might have revealed more. The difference in the amount of space they took up and the ability to use the DAC section of the RZ-1 meant it was a clear winner.
Maybe if my circumstances changed in terms of space then I'd switch to separates. Most likely I'd keep the RZ-1 and PMC DB1is for a bedroom/2nd system.
chebby
1,253
26
19,220
AirPlay can be sorted with a little £99 ATV connected at the back. (A bit of a retrograde step, in terms of reducing clutter, but it's quite small and easily tucked away.) At least the Unitis have more than one optical digital input so not a deal breaker.
Anyway, can't afford £1150 right now so the point is moot.
J
jcbrum
I prefer to go the AVI ADM9 or ADM40 route.
At least you then get the advantage of proper active loudspeakers, correctly matched to all the other components, and avoid the problems of passive crossover loudspeakers possibly mismatched to a non-optimised amplifier, such as can occur with the separate speaker 'all-in-one' devices.
JC
Overdose
279
chebby said:
Too rich for my wallet JC.
I don't know your budget and I cannot PM you, but Audiotec in Holland still had some ADM9.1Ts (Pre RS) at a good price, it's where I got mine. Still not 'cheap' exactly, but a lot less than the RRP.
Might be worth dropping an email before they all go.
Covenanter
88
34
18,570
Hope this helps
Bill
+1
Chris
tino
135
10
18,595
I think unless you are into hifi esoterica, one box solutions and small form factor solutions are becoming the way to go for more and more people, for reasons of cost, space and convenience. I'm not sure if sound quality is as big a factor as most people think so long as it's "good enough".
My very compact solution (see signature) is an excellent sounding solution for my needs. However, I still have a separate system which I hope to set up properly, and with the same source (SBT) there is a definite audible difference, but only because the separates amplifier is a valve amp. For semiconductor amplifiers, particularly those based on off the shelf Class-D modules, I think the difference between separates and all-in-ones is narrowing to the point where it is difficult to distinguish with a modest pair of speakers.
By the way, when people talk about one box solutions, if you are into streaming your personal music collection, then there is that "other" box that everyone seems to forget about ... a NAS or home server. I wish more manufacturers would allow for a solid stare drive to be inserted inside the traditional hifi streamer / DAC / amplifier box.
I'm not entirely convinced about embedding the music playback hardware inside an active speaker, but if manufacturers could standardise on a "void" inside an active speaker whereby you could plug in your own small digital player, then that would work for me :)
chebby
1,253
26
19,220
I don't really have a budget because I am not looking to upgrade. I am happy with what I have.
I am planning to buy something akin to my M-C603, or Denon CEOL Piccolo, to go in another - smaller - system in another room. (Or replace the M-CR603 in the living room and put that in the spare room instead.)
AVI actives and Naim Unitis etc. are not on the radar. Thanks for the encouragement but AVI actives would be total overkill (financially and otherwise) in either room.
Overdose
279
No worries, just thought you might have been holding off due to cost. I know I did.
Edit: sorry peeps, back on topic now.
abacus
Downsides: All in one
1. Probably won’t have enough power to drive more difficult or larger speakers
2. More chance of interference between each part
3. One power supply has to do everything
4. Heat generated can transfer to other components
5. Expensive if you want to upgrade (You have to change the complete unit)
6. One part breaks and you have nothing to listen too while it’s away for repair
Upsides: All in One
1. Convenience
2. Everything is designed to work best with each other
3. Less Cables
Downsides: Separates
1. Cables all over the place
2. Can look awful together
3. Need more than one Remote/App to control them
4. Takes up a lot of space
Upsides: Separates
1. You can optimise the balance to suit your personal preferences
2. You don’t have to have features that you don’t need
3. If one part breaks you still have the rest
4. Upgrades can be piecemeal allowing the cost to be spread over time
5. Looks more like a professional studio system
Personally I prefer Mix & Match as it allows me to get exactly what I want (No compromises), and still have something to use if one part breaks. (Also if I decide to upgrade I can do it in stages as finances allow)
In the end choose whatever suits, but at the same time also try and think ahead.
Bill
steve_1979
231
10
18,795
I actually like the look of a rack full of hifi boxes. Especially if they're all from the same manufacturer and are asthetically matched. 8)
In my experience as far as the sound quality and value for money are concerned 'all in one' systems are just as good as seperates at the same price. That said unless you go for an AV receiver there aren't many 'all in one' systems that have high powered amplifiers in them though. I think that there's a gap in the market of an 'all in one' system that has at over 100wpc.
