- Aug 10, 2019
- 2,556
- 5
- 0
So I'm considering switching to a low output moving coil cartridge, but for the moment I'd like to keep my Cambridge Audio 640p phono stage (which I'm quite happy with for my current high output Denon DL-160 cartridge).
I've read somewhere on the net that the way to match a cartridge to a phono stage is
G = 20 log (V1/V2)
where G is the gain in dB, V1 is the output from phono stage, V2 is the output from the cartridge.
If I haven't forgotten all my maths then this means that
V2 = V1 / 10^(G/20)
Now the CA phono stage can do 55 dB gain for MC @ 1 kHz, and my Audiolab 8000a amp inputs take 100 mV.
So I think this means V2 = 0.177 mV. Does that mean that I can use any moving coil cartridge whose output is at least that? Would I be cutting it too close with a Denon DL-304, which has an output of 0.18 mV?
To double check, using the initial formula I find that I'd need a gain of 54.89 dB for this cartridge, where the CA amp says that it provides 55 dB (@1 kHz -- what exactly does this mean?)
Someone might also help me with this line which I found on the web for my Audiolab amp:
Inputs: Phono MM: 2.0 mV/47k/85pF; Phono MC:
110µV/100ohms/3.3nF; CD, video, tuner, tape 1 & 2: 100mV/20 kOhm; Power amp: 707
mV/50kOhm
That's where I got the 100 mV for my amp. Also -- does that mean I can use a 110 microvolt MC cart with the amp's phono stage? Seems very low!
Maybe someone can explain all this gain/voltage business to me properly in case I'm going about this the wrong way.
G = 20 log (V1/V2)
V2 = V1 / 10^(G/20)
mV/50kOhm
