How high does your hearing go?
drummerman said:
ID. said:
you do know that's the sampling rate rather than how high a frequency is reproduced
Sampling rate is related to high frequency extension
Yes, but when trying to sell you high resolution products that's note the aspect they push when they show the lumpy squared off wave that 44.1 kHz gives you while the higher rates give you a much smoother and more analogue wave (but didn't some manufacturers get pulled up on that and had to stop using those kinds of images in high resolution audtio advertising?).
Just did the test again. I can hear to over 15khz today.
Last time I topped out at 14khz. Go figure.
Perhaps moods, time of day etc affect our high frequency hearing.
50yrs.
Indeed. Counter intuitive though it is, 44.1 kHz sample rate allows you to reconstruct a 20kHz sine wave perfectly, no humps, bumps or little staircase pictures.
17khz/18khz right now. Just turned 40 last week. Always had very sensitive hearing in the high frequencies, loads of stuff sound harsh and strident if played just a little bit too loud...
If your musical tastes are electronic and synthesised then fair enough as that type of music can stray in to 17-18Khz. If not, and physically played instruments and vocals are sounding harsh, then you definitely need to change something in your system and/or your choice of music.
insider9 said:
Not necessarily. May I ask which side of 50 you are?
59! I put it down to 14 years working in the press shop at Dagenham, (1978-92), and a love for motorbikes *biggrin*
insider9 said:
Nothing to worry about in that case, it's only natural.
Yep. Slow decay of the body and mind. Regressing into childhood, the growing of hair in the most unusual places.
These are just a few things you can look forward to and I'm not too far behind you.
Happy weekend.
Happy weekend.
*biggrin*
I'm already there with most of the above. Life is like a toilet roll... when it's new it rotates very slowly... when you get towards the end of the roll... well...
