Love the thread guys, keep it up. :clap:
Thought I'd share few experiences and thoughts of my own.
I am not of the school of thought that amplifiers should be picked by tonality first, then worry about how competent they are latter. I always look in the electrical capabilities and build quality first, then when I get my tech kinks satisfied I may audition an amp but most often I buy them without auditioning. Crazy, init?
I think amplifiers don't "sound", they "amplify" and their tonality is overated and misleading.
I believe transducers sound, amplifiers amplify, cables conduct, shelves and stands hold. YMMV.
When I buy an amp without auditioning it first, I do my homework what my choice of speakers need electrically and for my subjective sonic taste. Any variation in sonic characters between amps it takes me 2 days to forget it ever existed. But I will not forget when my amps voltage rails sag in congested passages on Mahler and speaker cones want to fly away out of their baskets.
I also believe in the policy of you get what you paid for, and although there are exceptions the rule applies.
So here is what I look in an amp from hardware POV and these are still just my preferences.
- "POWER" Jeremy Clarkson.
Doubling down power from 8 ohms to 4 ohms and a wet dream doubling down to 2 ohms. Or at least separate windings on the transformer for different loads.
- High current design, simple topology.
- Dual mono construction with separate PSU or sharing transformer with separate windings for each channel.
- MOSFET first, bipolar second, more tranzistor per channel the better. Tubes acceptable only in low power application (preamp).
- Oversized Power Supply Unit (PSU). Especially oversized transformer exceding 500VA (if pushed to its limit, gauss field gets denser and transformer hums. I hate that). Preferably Talema or Noratel.
- Regulated PSU, multiple voltage rails.
- Lower output impedance, wide bandwith, fast slew rate and 3 digit dumping factor,
- Larger heat sninks.
- Quality caps with higher temp spec, voltage, ripple current, lower impedance and ESR.
- ALPS conductive plastic volume pot. No tone controls, selectable loudness etc. I use my DSP in JRiver if need be.
- Elna Silmic II in signal path. I love them. I don't mind WIMA film caps as well.
- Quality opamps (preferably none), diodes, metalized type resistors and relays.
- No wires flying arround holding on zip ties. All components well situated on PCB is better. Otherwise I will hear the fridgerator in my Paco de Lucia.
- Driver tranzistors and/or preamp running in class A, power amp high biased AB is what I prefer over full blown Class A amps. They are hard and pricey to live with. Don't mind a full class AB at all, if its well done.
Well it is a big-ish list but its boxes I tick when I'm shopping arround. Its never a perfect 100% to my satisfaction mainly because the more boxes I tick, turns out more money I have to cough out. So every next amp I get I tend to cover as many of these preferences as possible for my budget.
I too like most here roam in the commercial sub 1000 GBP, this is why i got my Roksan. Previosly I had Harman/Kardon HK6900, a real beast but getting old and with some issues. Prior to that I owned a Marantz PM-80 MkII, Kenwood KA-9X, Pioneer A400 (just for fun) and few more.
I don't expect people outside of this hobby or just begining to have such a list or understand the basic terms used, but for someone who is in the deep end, I find it odd to "use the ears" and not much between them. What seems pleasant in the hifi showroom or even in your room, in your system, it may be just a brief honeymoon and the relationship can turn sour very quick and divorcing from your new gear gets really costly.
From that perspective I would trust a knowledgable dealer and build that relationship, so I don't have to learn, make lists and pay for costly learning mistakes. More time and money to enjoy the music and not this OCD of a hobby. Easier said than done, though.
Sorry I waffle on a bit. :wave:
