Home Cinema Set-Up from Scratch - Beginner Questions
AlCapwnUK
10
I am looking at upgrading a very dated 27" Sony HD (ish-1080i) TV set up that has seen me through 6 years of uni.
Working with a fairly small room.
I am fairly confident on the TV upgrade (Panasonic Viera Tx-40cx680b):
- http://www.johnlewis.com/panasonic-viera-tx-40cx680b-led-4k-ultra-hd-smart-tv-40-with-freeview-hd-and-built-in-wi-fi/p1961457
But the sound system is new to me. I have only ever set up a very modest PC audio system with audioengine a2s running off of a dragonfly DAC.
I want to build up towards a 5.1 system to soften the financial blow.
Am I right in thinking that I need to start with an AVR?
My current thinking is that I need something like....
- Yamaha RXV379 AVR
- Q Acoustics 3010s x2 - as front L/R
+/- Q Acoustics 3090c - as centre
Giving me a 2.0 or 3.0 set up.
Then later adding the rear and subwoofer.
I'll be plugging in:
- PS4
- Virgin TiVo box
- Wii U
Would be nice if my girlfriend could plug her iPhone in easily as well.
Quick questions:
- is the Yamaha AVR good enough?
- do I need the AVR initially or can I start with 2.0?
AlCapwnUK
10
Current TV is Sony KDL26S3000
The sound on it is actually very good for a flat(ish) screen - but the screen size and picture quality are not up to scratch anymore
Son_of_SJ
325
Yes.
Yes, you do need the AVR, otherwise you won't get any sound at all!
I'll just add that I'm glad that, subject to funds, you are going to build up your system - you certainly don't have to buy it all at once. Start with the Yamaha and two front speakers, and add the rest as money becomes available.
