- Aug 10, 2019
- 2,556
- 5
- 0
Morning
I am enjoying a hi-fi revelation at the minute - I've recently purchased an Audiolab 8000x7 power amp, imported an Outlaw processor, and upgraded my front speakers to Proac Response 1.5's.
The improvements in sound quality from my previous set up are amazing but the only way I can currently bi-amp my front speakers is by using budget rca splitter leads costing about £5 each.
As far as I can tell there is no facility to re-assign the surround back channel outputs from the processor, or to get the amp driving 2 outputs from a single RCA input.
Therefore, my only solution appears to be using RCA splitters, or trying to find a reputable cable which is available in 1xRCA male to 2xRCA male.
Is anyone aware of these cables? I've had a quick search on google but can't find anything. And if not available off the shelf, will someone like custom cable be able to make them for me?
What would you recommendation be for actual cable to use - I will probably purchase the other 3 cables I need at the same time (for centre and rears) and have them all of the same cable, terminations etc.
Any help gratefully received
Steve
Steve
