HiFi quality radio? - Chebby et al to the rescue, please
Charlie Jefferson
229
Up until quite recently I've listened almost exclusively to Radio 4, and as such, not needed anything else other than a kitchen transistor radio and Sky box into DAC in the living room to do so.
However, I have found myself sampling more and more Radio 3, in the car (car radio), and on the train/on foot (iPad), and wondered what would be the best sounding option for listening in the evening when I have my hi-fi (see below) in the equation.
Availale options:
1) a Videologic DAB tuner gathering dust in the garage (and an outside DAB aerial available too).
2) Sky box into DAC
3) iPad streaming to DAC
4) a new tuner? (less than £300 budget if this was the way to go)
chebby
1,251
24
19,195
In my case the best Radio 3 is from FM with a rooftop aerial.
Next is TuneIn Radio Pro app from my iphone via AirPlay. (Gets the whole 320k.)
Then Freeview Radio 3 from my Humax (and, of course, that means I can record a radio programme without being around). In your case this would be the Sky option.
Lastly, DAB. Sounds ok (with rooftop aerial) but more for convenience really. (More 'ok' than I would have expected from past experience.)
If you elect to get an FM tuner then spend £50 to £100 on ebay for a really good condition Denon TU-260L (or similar) and spend the rest of your budget on a cracking good rooftop FM + DAB aerial installation. (Not of those awful circular 'omnidirectial efforts!)
[Late Edit] Quick, quick this looks good (new in box)...
Denon TU260L II
plastic penguin
Like Chebby I'm an avid radio listener - a dedicated tuner will be hard to beat. The good thing is there seems to be more choice on the s/hand market (perceived comment).
Denon, Marantz, Rotel, Arcam... all have their boots [still] firmly in the tuner market.
Charlie Jefferson
229
Denon TU260L II
That's the very model of tuner I used to own! Sold it because my former abode had terrible FM reception and when I moved house I invested in a DAB tuner and aerial. The latter, my wife now reminds me, is no longer in situ. I agreed to it's removal last year prior to house renovation work. (She is now grumpily, yet semi-gleefully reminding me that she thought it was a mistake, and said so at the time! She likes being proved right, of course).
Will try the app you mention, and proceed from there.
Thanks.
Andrew17321
24
I have found that the internet 320 kb/s AAC is by far the best, using Sonos through a Rega DAC into an amp. Better than any FM I have received through a good tuner. Using the same stream via the TuneIn Radio app on an iPad and streaming to a DAC should be equally good, providing that the iPad streaming (Airplay) is up to the job.
Andrew
bigblue235
82
I was lucky enough to move into a flat with a good quality FM feed pre-installed. But I never use it, I just use Internet radio through my iPod and Apple TV. Sometimes use the Sky box. I don't notice much difference in sound quality, and I enjoy the flexibility and sheer choice.
Charlie Jefferson
229
I think I agree.
I bought the Tunein app and streamed a few Radio3 programmes, and they all sounded pretty good. I think I'll leave the DAB tuner to gather even more dust.
Cheers all.
bigblue235
82
Good stuff, glad you're sorted.
The other thing I find handy with TuneIn is the ability to record. I don't imagine many of us still have a recording device connected to the tape loops. Ah, those were(n't!) the days.
Reggie Mental
Radio 3 sounds great on FM through my old Leak tuner. Just goes to show how extended frequency response isn't essential in hifi.
chebby
1,251
24
19,195
bigblue235 said:
Good stuff, glad you're sorted. The other thing I find handy with TuneIn is the ability to record. I don't imagine many of us still have a recording device connected to the tape loops. Ah, those were(n't!) the days.
TuneIn Radio Pro recordings are not transferable to iTunes though :-(
I am now using our Humax HDR-Fox T2 to record from Freeview radio. Obviously the recordings are not going to be 'permanent' (like cassettes), but I am looking into using USB memory sticks for stuff I want to keep. (They are almost cheap enough to label and keep for this purpose.) However, I don't know yet whether I will be 'locked' into having to play them back on the Humax or even whether they will only play back on our specific Humax (and no subsequent Humax machine - or other PVR - we may own in future).
Ideally I will be able to play back/download the contents of the memory sticks on a computer and import/convert the files to iTunes.
I need to research this (or open a new thread) as I don't have any spare memory sticks to experiment with.
Sospri
28
I have the same Hunax as you and yes you can download onto a memory drive and play them on a computer, I have done this with TV films ect, many times.....
bluedroog
8
On a side note…you should try the Linn Radio stations, I pick them up through a Squeezebox and they sound really rather good.
