- Aug 10, 2019
- 2,556
- 5
- 0
Hi People,
I know it sounds crazy but could wrapping tin foil around cheap/generic power cables cut out the RFI interference and improve the sound or picture quality? When it comes to specially made hifi power cables are they simply cutting out the RFI or are they doing something more?
Because if all the expensive cables are doing is cutting out RFI, couldn't one simply use tin foil to acheive the same result?
Also, is it true that placing a brick or heavy object ontop of ones dvd/blu ray player can cut down vibrations? I have tried putting cheap isolation feet under my player which certainly makes a difference to the picture and sound.
