iceman16 said:Please...anyone who does'nt believe cables can make any difference Please don't reply!
Open to those who believe..sorry.The_Lhc said:iceman16 said:Please...anyone who does'nt believe cables can make any difference Please don't reply!
So you're not looking for an open discussion on the subject then? In that case...
THEY'RE CHUFFING GREAT!!!
Thanks Chebby..I do appreciate that..just replaced basic fuses to AMR gold 13a(power chords) and yes they make difference but not massive..I do believe(conductors,from silver to gold etc) can make difference!chebby said:
sogophonio11 said:So are Russ andrews fuses 🙂 About an inch! 😉
sogophonio11 said:Take care of your mains infrastructure, from the consumer unit to your system. Its all about cost of course. These plug fuses are properly designed they just use better litz wire, but still blow when they are supposed to! The benefits of this approach will be clearly evident. Upgrading further down the chain will not bring the expected performance boost you are looking for, unless you take care of your mains first!
Plenty of good articles on the web. Check out Russ andrews site also. You dont have to buy his products, but a wealth of very good advice etc.
sogophonio11 said:To my knowledge, there are no internal equipment fuses available? But they sit on the PCB in most cases and would not make much of a difference any how. The ones in the plug do.
