sogophonio11 said:Oh dear! Another obtuse individual. No difference/ dont believe, etc ,etc! And your qualification to speak sir? Mains considerations most definitely do make a profound difference, and affect (Not effect) The overall performance of an audio system.
My qualification(S) to speak sir? Well not in any particular order of importance:
1) Over fourty years in the industry.
2) More than fourty years as an enthusiast
3) B.Tech(Bachelor of technology) Electrical engineering
4) Bsc(Hons) Sound engineering (Southampton)
May i be so bold as to suggest? Know what you are talking about before trying to give advice here! People who post on this (And other forums) Mostly know there subject. And are true enthusiasts, who only want to help where they can!
iceman16 said:Just received Hifi-tuning supreme (1a) to try inside my cdp. Will report back later
sogophonio11 said:Sorry i lied! No Qualifications to speak of. Play :wall: No thanks :wave:
iceman16 said:This will be sent back to the dealer for full refund NOT for the reason I did'nt hear a difference but for the sound which I did'nt like.
altruistic.lemon said:Expectation bias is believing there will be a difference. Therefore, criteria met.
iceman16 said:To be fair Cno..these fuses got some great reviews on the net and many are happy with them. But IMHO thats not the case, these may be system dependent and subjective to the listener. Unfortunately they did'nt work for me and I won't use them even if they will give to me for free😉
CnoEvil said:altruistic.lemon said:Expectation bias is believing there will be a difference. Therefore, criteria met.
IMO. The expectation (if there even was one), was likely to be that the sound would be improved, otherwise what was the point......so criteria not met.
Placebo should have made it sound better, as it was expensive (for a fuse).
altruistic.lemon said:No, it is as I said. The expectation is believing there is a difference. Whether the difference is good or bad doesn't come into it. Plenty of info on the internet if you want to check.
altruistic.lemon said:Cno, not being harsh, but I think that's called denial. You win some, you lose some, that's life. Luckily in Oz we don't have fuses like here, so it doesn't come into it.
